R3spcts Blue Smurf MX5
Turned out to be 2 issues, the heater seems ok, but the floor is soaked, but its just water, so either a leak or aircon is not draining, i used it last night due to fogging, but its soaked so might still be a leak somewhere.
The heater hose that goes around the back of the head had a pin prick hole, wasnt dripping, was squirting a fine jet, so was hard to see until i had it running and a light pointed at it, hose wasnt even wet or dripping. Been told that they are only 20 each new from mazda, so will order 2 new ones, but cut damaged piece off and pushed on further and put a new clamp on for now.
Im picking that aftermarket headers would make a huge difference to these engines, the factory collector is rubbish, cant wait to make a new one.
I looked into aftermarket headers but the stocks ones arent that inefficient, they do crack though so replacing them can be cheaper.
My understanding from the results I read on the dyno are a 1hp gain if your lucky, thats with no other work done to the engine. I would rather spend the money on a better flowing cat.
