NA Bilsteins - NB Top hats...?
Hi Guys, our silver jap imprt 91 (which is either an R package or near enough to it) has bilsteins and quite low springs.
After putting HSD's in my red car "Wee1" I honestly can't really bring myself to drive the silver one anymore. It just bumps and crashes it's way around and is just horrible. I really can't say enough good things about the HSD suspension, truly amazing the difference.
I presume the problem is mostly becasue it is riding on the bump stops so often. I know the valving isn't the greatest but that is the least of the problems at this point.....
Would fitting NB rear top hats help. From what I have read it makes a huge difference by providing more travel and limiting the "sitting on the bump stops" problem.
I guess my concern/question is will installing the NB top hats mess with the ride height or anything else?
It couldn't just be that simple could it, it never is!
yes it will give you more travel but will lower the car appox 5-7mm. You will have trouble fitting the bushes onto the na shocks as the shaft is not quite long enough. I have done it on my car but it did take a bit of mucking around. Upgrade the bumpstops while you have the shocks apart, the standard ones are rubbish.
