Driveshaft safety loops
Post by WideOpenThrottle » Fri May 18, 2012 4:22 pm
Drive-shaft safety loops
2.5. A front-engine, rear-wheel drive low volume vehicle that has undergone
an engine conversion, or has had its factory-fitted engine significantly
modified, such that a significant increase in power or torque has resulted,
must be fitted with an effective 360-degree front drive-shaft loop,
mounted within 150 mm rearward of each front drive-shaft universal.
So does any one know the min sizes of plate?... as i have some 25mm x 3mm flat mild steel lying around.
last_resort14
Post by last_resort14 » Fri May 18, 2012 5:08 pm
Lol, double that, mine had to be 50mm x 6mm.
Post by WideOpenThrottle » Fri May 18, 2012 5:49 pm
last_resort14 wrote:Lol, double that, mine had to be 50mm x 6mm.
Boody hell!!!
Post by Angreal » Fri May 18, 2012 7:23 pm
So if I fit a supercharger ill need these also?
Post by WideOpenThrottle » Fri May 18, 2012 8:07 pm
Yup! :D
Will I require LVV certification if I increase the power of my engine?
LVV certification will be required if the increase in power is more than 20%. Adding a supercharger or turbocharger automatically requires certification
Post by SLYDIT » Fri May 18, 2012 8:47 pm
mine was certed without one..maybe it was done before that was needed
Post by WideOpenThrottle » Sat May 19, 2012 8:22 am
Maybe it depends on the certifier then, so i shall only do it if he directs me too!
Post by SLYDIT » Sat May 19, 2012 1:17 pm
the mx5 runs the same driveshaft unis as the RX7 which came with a 13B turbo, so i think theyll be up to the job. certainly no more risk than any other RWD car without a hoop.
Post by Donovan » Sat May 19, 2012 8:02 pm
I wonder how that is going to go with my one, sure I am tripling the HP rating of the what the MX5 body had in there, but all the engine/trans/running gear is all stock Holden HSV (well apart from the shortened driveshaft and axles), so in theory nothing have be upgraded as far as that is concerned, it just happens to be in a different body. Guess time will tell.
Post by WideOpenThrottle » Sun May 20, 2012 8:53 am
Donovan wrote:I wonder how that is going to go with my one, sure I am tripling the HP rating of the what the MX5 body had in there, but all the engine/trans/running gear is all stock Holden HSV (well apart from the shortened driveshaft and axles), so in theory nothing have be upgraded as far as that is concerned, it just happens to be in a different body. Guess time will tell.
I agree!-you shouldn't need one.
last_resort14
Post by last_resort14 » Sun May 20, 2012 9:11 am
With the driveshaft being shortened, ie cut and welded, i can imagine they will definately require the driveshaft hoop.
Post by WideOpenThrottle » Sun May 20, 2012 10:19 am
Hi Donovan...a good read here.
http://www.lvvta.org.nz/documents.html#standards
Engine & Drive-train Conversions 85-40(00) ...section 2.5
Post by Euen » Sun May 20, 2012 5:39 pm
I got away with a length of 6mm stainless wire rope stretched across the tunnel.
