Height Adjustable shock help
I have just bought a set of height adjustable sruts and will be fitting them next weekend, what I would like to know is the easiest way to set them up. Is it all just trial and error or should I set up front first then the back? etc. Any help from someone that has done this would be great.
I put mine in and just adjusted accordingly, took a couple of go's. jack up the car, whip the wheel off and adjust by instinct. put the wheel back on drop the car, bounce on the gaurd (carefully) stand back and see what it looks like...
The american forums generally suggest 12.5" front and 12.75" rear from centre of wheel to gaurd as the best height for optimum handling, or thereabouts.
They also have suggested wheel alighment settings for this height. Check out 949 racing for details (if you haven't already)...
Did they come with the spanners to make the adjustment with?
Do you mean struts or shocks? Struts would have a hard time being useful in our cars
More seriously, yes it is largely trial and error. I used a set of digital calipers to accurately match up the distance between the locking collars on each shock. I'm running ~11.5" rear and ~11" front. Looks and handles great, and I can still manage it over many speed bumps, even though my chassis rails are only about 70mm off the ground...
Also allow time for them to settle back down, I pretty much did my by eye, none of this laser trickery for me (only cause I didn't have one around). Whip the wheel off, adjust, do some rough measurements to make sure the sides where kind of even, wheels back on, quick blat around the block, and measure again (I did my measurements from the centre cap).
If you wanted to get tricky, could always have one side higher than the other to allow for the weight of the driver when they are sitting in there?
do you plan on doing any other modifications that will require certification? brakes?turbo?etc
it will cost the same if you only want to cert your shocks as it would to cert 10 other things
I use John Brett for certification and he is mobile and will come to you as long as you can provide him with a hoist. call him on 0800LOWVOL
