by WideOpenThrottle » Thu Apr 19, 2012 7:24 pm
How do you differenciate an 1800 box to a 1600 one?
Is there a number stamped on them or what?
Looking at maybe getting one while i have the chance while everything is out!
Cheers for knowing what i don't!
last_resort14
by last_resort14 » Thu Apr 19, 2012 8:15 pm
they are the same.
ive had 2 na6 boxes, and then the one that came with my na8 motor was identical. ive had one that was a 1.8 out of a newer car and when it got rebuilt the guy said it had a double synchro on second or something, but as far as im aware they are the same box
by WideOpenThrottle » Thu Apr 19, 2012 8:38 pm
So... just the internals are stronger then?
Still it would be nice to identify one without a shadow of doubt!
Wouldn't like to think i bought a 1600 one when i have already got one!
last_resort14
by last_resort14 » Thu Apr 19, 2012 10:08 pm
nah the internals are the same, theres no difference. unless its a 6 speed of course
by Born_disturbed » Thu Apr 19, 2012 11:44 pm
NB ones are stronger than NA ones, but all NA ones are built equal
by Timmo » Fri Apr 20, 2012 7:16 am
But they do vary by year don't they? In the shifter assembly?
by WideOpenThrottle » Fri Apr 20, 2012 7:29 am
Looks like i will spend the coin on something else then!
What would i do without this Forum! cheers guys.
by WideOpenThrottle » Fri Apr 20, 2012 7:59 am
Timmo wrote:But they do vary by year don't they? In the shifter assembly?
It seems they really only vary in final ratio's-the 1600's are 4.3.1 while the 1800's are 4.1.1 plus an improved second gear synchroniser!
Not a stronger box as i had originally thought!
ross
by ross » Sat Apr 21, 2012 8:29 am
The small dustboot around the base of the gearstick is 60mm dia on the 1.8 and the 1.6 is 75mm.
Also a slightly different baseshape and the rubber boot is taller on the 1.8.
by Kieran » Mon Apr 23, 2012 2:49 pm
and the 6 speed is a 3.9.1
last_resort14
by last_resort14 » Mon Apr 23, 2012 6:23 pm
The 4.3:1 , 4.1:1 , 3.9:1 etc final drives, is the diff ratios. Nothing to do with the gearboxes.
by WideOpenThrottle » Mon Apr 23, 2012 7:08 pm
last_resort14 wrote:The 4.3:1 , 4.1:1 , 3.9:1 etc final drives, is the diff ratios. Nothing to do with the gearboxes.
Yep! i stand corrected-never read my book correctly!
