Mystery 5
Mystery 5
Hello all, I'm new here so forgive me if I've put this in the wrong place.
I'm on the hunt right now for either an NA8C or NB, I'm torn between the practicality of the NB and the original looks of the NA, but time will tell there.
Now this 1.8 NA has caught my eye but it's a bit of a conundrum
(Apparently I can't post you a link yet but search for MX5 special on Trademe and it's the only NA in the results)
You see it appears to be a US spec M-Edition. It's an M-Edition colour scheme and even has M-Edition badges on the side, yet it is right hand drive. Now it would be madness to convert an American version of a Japanese car to right hand drive and the current owner isn't aware of the back story, so can any of you tell me whats going on here?
old scrubber
Ha, that's my old car
(Edit- In fact its still showing in my sidebar....will change now to my current NB8 RS
In my time of owning it I put in the roll bar, the front lip, the airfilter and heat shielding. As mentioned in the advert, I also gave the buyer the standard airbox if you want to convert back...you might need to remove the heat shield from the exhaust to fit it back on. The filter did give a bit more punch in the mid range and a more induction sound.
It is a nicely maintained car- The seats were recovered just before I bought it although they look a bit more worn now. The clear coat on the back number plate panel was also starting to go (which has continued to do so judging by the pics). Other than that it's straight- I did do two track days in it but I'm a sympathetic driver
(Edit- My memory was wrong!)
That asking price is slightly higher than they paid for it a year and a bit ago.
Not wanting to call you out by any means, but I think this is always a dangerous statement to make. Was this ever dyno tested, or is it your butt dyno talking?Timmo wrote:The filter did give a bit more punch in the mid range and a more induction sound.
Very tidy car nonetheless, and good of you to give the OP a heads-up on price
Oh just remembered that I also bumped the timing too...it should still be alright on 91 RON but I was using 95 RON
Plastic top tanks on radiators have a set life and can crack/perish- I think from memory it had actually been done by the previous owner? I gave the new owner all the previous service history and history of work I did to it so you may be able to see if it was.
