4age?
Post by evel » Wed Dec 21, 2011 6:16 pm
SimJen wrote: An N/A 1.8-2 Litre could easily put out 200+hp with the right work and $$, more if you're willing to have a non streetable motor.
do u mean that stroking it out to 2.0 makes it a illegal motor or u could spend more to get more but it then becomes illegal?
Post by Euen » Wed Dec 21, 2011 6:31 pm
Not illegal, just very expensive. My engine is out to 1929cc which is about the limit without stroking. I'm getting about 140rwhp and it is reasonably streetable although I wouldn't like it as a daily driver. I could probably get a bit more but that would require a lot more $$
Trying to get big HP out of a normally aspirated 1.6 or 1.8 is very expensive.
Gravelben
Post by Gravelben » Wed Dec 21, 2011 6:31 pm
I think more that the tuning necessary for that power would make it somewhat less suitable for normal road driving - ie extreme cams giving big top-end power but not much low down, lumpy idle etc.
Post by evel » Wed Dec 21, 2011 6:42 pm
Euen wrote: Trying to get big HP out of a normally aspirated 1.6 or 1.8 is very expensive.
but really u dont need big power in a 900kg car. i reckon saving up to a 3sge would be a quality investment. There aren't any 200hp+ motors that Mazda make apart from Rotors are their?
Post by Donovan » Wed Dec 21, 2011 8:11 pm
r3spct wrote:The rotary option is difficult ive heard has the trans tunnel is too low and needs more clearance about box to raise the engine. v8 conversion needs a new front subframe.
The rotary conversion isn't the easiest if you are doing it for the first time, but there is a trick to it, and if you can find someone who has done it before, then it makes life a lot easier. Don at Autoways in Hamilton has done a conversion and I believe that he still has the car.
I have seen a couple of Lexus V8 conversion done without changing the subframe, one of them the whole conversion only cost him $8k apparently, and that included the cost of the car, but it is running the Lexus auto and he is a mechanic, so his labour was zip.
Gravelben
Post by Gravelben » Wed Dec 21, 2011 10:44 pm
evel wrote:There aren't any 200hp+ motors that Mazda make apart from Rotors are their?
KL-ZE 2.5 V6 is 200hp, KJ-ZEM 2.3 SC Miller-cycle V6 is 230 (but apparently doesn't fit in an MX5), I'm sure the newer MPS motors make more than that too!
SimJen
Post by SimJen » Thu Dec 22, 2011 7:40 am
2.3 Duratec would be the go from the Mazda 3's/6's.
Same motor as in the Caterham 7's makes big horsepower with not a lot of work, not exactly cheap to buy though so just stick with FI
91 Eunos Roadster Red
04 Avensis for the Kids
01 Ducati 996
80 Honda 400 Cafe Build
Gravelben
Post by Gravelben » Thu Dec 22, 2011 8:20 am
Will be interesting to see what people are doing with the Mk3 over the next few years as I think thats basically a Duratec lump too :)
SimJen
Post by SimJen » Thu Dec 22, 2011 8:23 am
Caterham has some roller barrel throttles that liberate a ton of power along with headwork and cams. 270hp NA!
01 Ducati 996
RMS
Post by RMS » Thu Dec 22, 2011 9:13 am
+1 on the turbo, I don't get the appeal of SC's but then I've never driven one.
Post by evel » Thu Dec 22, 2011 9:43 pm
SimJen wrote:2.3 Duratec would be the go from the Mazda 3's/6's.
are the 2.3 Duratec turboed?
