NB NA Swap (Airbag)
NB NA Swap (Airbag)
Post by Angreal » Tue Dec 20, 2011 12:11 am
I'm doing the NB NA interior swap and got the airbag module out from the new dashboard. Seeing as I never had an airbag to begin with and the current one has been triggered, how do I remove the trim off the module so I can get a cover fabricated? Is the best approach just to saw along the metal rod so that it slides straight off?
Post by sprsta » Tue Dec 20, 2011 10:01 am
there will be like fifty small tabs holding the plastic cover onto the metal airbag you should be able to pry them apart without cutting anything
2low2c
Post by 2low2c » Tue Dec 20, 2011 11:17 am
do as sprsta said then i just glued the cover back together and covered it in black vynl the same as the dash
Post by Angreal » Tue Dec 20, 2011 8:18 pm
Haha prying them off is so obvious. I can't believe I didn't think of that one. I tried many things including bending, pushing, squeezing and then decided I was going to get my hands on an angle grinder and try cut slots into each one :roll:
