MX5 Gearbox Noise
MX5 Gearbox Noise
Who can I get to look at it in the Auckland area? Id prefer to take it to someone who specialises in MX5s, so if anyone knows someone, it would be great.
The sound is a meshing noise which occurs on deceleration, its worst in 4th, and bad in 3rd, but also does it in all other gears. It goes away when I push the clutch in. It also does it to a lesser extent when I'm accelerating.
It's going to drive me insane at this rate!
And mine does it too although i think that if you reset the power point frame up to factory specs the noise may lesson to some degree as i have noticed while having mine in & out several times.
I also suspect bushings,aftermarket/lowered springs,worn engine/diff mounts, etc add to the noise.
my old gearbox did it and the replacement does too..it seems to be a harmonic frequency that goes through the driveline... annoying but incredibly frustrating (and expensive) to solve as youd have to swap out gearbox and diff and get a combination of parts that doesnt do it
