Engine Breathing Hose
Post by Angreal » Fri Aug 12, 2011 10:19 pm
So while I was removing my cam cover I managed to destroy the breathing hose that goes from the engine cover to the intake pipe. It had gone hard and ended up cracking as soon as I tried to pry it off.
Where would I be able to get a replacement hose, are there quality ones that won't go hard and brittle, and do they come in any other colours other than black?
Post by Angreal » Fri Aug 12, 2011 10:32 pm
Also while I'm on the topic of parts breaking and stuff... where does this go? I think I have it left over from when I had the covers off painting them. I thought it was a random piece of rubber lying in the garage and not from the car... Quite possibly a good thing I haven't been able to start the car.
http://www.broomfish.co.nz/product_info ... cts_id=920
Post by punkoutnz » Sat Aug 13, 2011 10:17 am
The bits in that link are from the sump. One goes at each end around each of the half moon shaped bulges around the crank seals. You're gonna have some chronic oil leaks if you've taken the sump off and not put those seals back in there!
Post by Euen » Sat Aug 13, 2011 12:40 pm
Do you mean the hose that goes from the PCV valve to the inlet? If so it is usually a shaped hose from Mazda. (Any colour you like as long as it is black)
You may be ably to find something in coloured silicone that would do the job but not sure where.
Post by Angreal » Sat Aug 13, 2011 4:50 pm
Phew, I didn't touch the sump so I'll stick with my original assumption that the pieces of rubber I found on the floor of my garage were there to begin with...
I think I'll go put an order through from Mazda for the hoses then since I got told that silicone hoses won't be sufficient. Hopefully I can find something soon though.
