LSD
Toolbox
LSD
Post by Toolbox » Sat Jul 30, 2011 3:06 pm
Hi All...What is the easiest way to tell a 1.8 LSD diff from a non LSD diff.
old scrubber
Post by old scrubber » Sat Jul 30, 2011 3:24 pm
jack up both rear wheels , tur one by hand, if the other goes in the same direction it is a lsd, if it goes backwards it is not,
last_resort14
Post by last_resort14 » Sat Jul 30, 2011 7:08 pm
The above trick doesnt work for the Torsen style LSDs that 1.8 mx5's came with.
My method would be
1.find open area
2.turn full lock
3.rev car to limiter
4.drop clutch
5. if LSD-Enjoy :D
Post by Kieran » Mon Aug 08, 2011 10:59 am
last_resort14 wrote:The above trick doesnt work for the Torsen style LSDs that 1.8 mx5's came with.
My method would be
1.find open area
2.turn full lock
4.drop clutch
5. if LSD-Enjoy :D
AGREE
mr_pool_pool2000
lsd
Post by mr_pool_pool2000 » Mon Aug 08, 2011 6:02 pm
one wheel on the grass one on the road some heavy acceleration is good to tell.
_if your LSD is very worn it will behave weirdly sometimes kicking inside wheel and other times locking both together< i had one that i used on the gravel roads allot and this happened to it after a while.
shimms can be replaced !!!
Post by Angreal » Mon Aug 08, 2011 9:10 pm
Silly question I know, but I'm going to attempt these methods but what would the outcome be if I had an lsd and if I didn't have one?
mr_pool_pool2000
Post by mr_pool_pool2000 » Mon Aug 08, 2011 9:41 pm
if you just drop the clutch in a straight line you will surly get both weels going at first because of the emense pressure. - regardless of lsd or not
the best whey is the one wheel on slippery surface and one on hard and to get rolling before applying the throttle - power is going to be plenty to spin both wheels even stock with one wheel on tar and one on grass if you mark the tar then you are lsd if not you will spin the grass wheel heaps leaving a trench :(
RMS
Re: lsd
Post by RMS » Tue Aug 09, 2011 9:14 pm
mr_pool_pool2000 wrote:one wheel on the grass one on the road some heavy acceleration is good to tell.
I thought that the Torsen diffs act like an open diff when there is a massive difference in grip though?
aidwano
Post by aidwano » Wed Aug 10, 2011 6:36 pm
Both early and late model torsen can supply 2.5x torque to one wheel over the other. Apparently.
RMS
Post by RMS » Mon Aug 15, 2011 8:17 pm
I got my '95 Torsen diff on Saturday and it's possible to see the helical gears through the filler plug hole.
Not sure if this is possible when it's installed in the car but I reckon with a torch it would be doable.
Also the later Torsen's are a different design but I think it would still be pretty obvious.
Brainflex
Post by Brainflex » Tue Aug 16, 2011 6:58 am
You can see the torsen gears through the filler hole when it's in the car. Thats how I confirmed mine was a torsen diff.
