tyre air pressure
mr_pool_pool2000
tyre air pressure
Post by mr_pool_pool2000 » Mon Jul 04, 2011 11:03 pm
hi just purchased some nwe tyres they are re001 205 50 15's adrenalin and am wondering what air pressure to run they feel a bit sloppy when you get close to edge of traction
Post by Stevo » Tue Jul 05, 2011 6:19 am
I'm currently running 32 psi.
Post by Growler » Tue Jul 05, 2011 12:26 pm
I run 32 as well. It helps stiffen up the sidewall a little...
Post by SLYDIT » Tue Jul 12, 2011 10:17 am
50 series profile isnt exactly low profile these days so you are going to get a bit of squirm. even my 205/45 toyos move around a bit on the limit. but thats half the fun! :o
i generally run about 32-34 when dry and drop it to 30ish in the wet
Gravelben
Post by Gravelben » Tue Jul 12, 2011 11:37 pm
Like they said, anywhere around 28-34 (depending how it feels) should be fine. RE001 have pretty decent sidewall strength so I'd probably go with 30-31 to start with.
The sloppy feeling may well just be as they scrub in, new tyres are often a bit squirmy at first.
