BCImports Short Shifter
m4vr1k
Post by m4vr1k » Tue May 31, 2011 10:34 pm
Considering buying one of these, just wanted to know if anyone has had any issues with longevity.
http://www.trademe.co.nz/motors/car-par ... 172581.htm
Zac
Roses are red
Violets are red
Trees are red
Oh fuck, my garden's on fire
Gravelben
Post by Gravelben » Wed Jun 01, 2011 5:53 pm
Had one, didn't last long before the plastic bushing on bottom of shifter disintegrated. It did make the shift action very short, but a bit notchier than standard as well.
m4vr1k
Post by m4vr1k » Wed Jun 01, 2011 7:19 pm
Would you recommend purchasing one, based on your experience? I don't mind a bit of notchiness, comes with the territory.
Roses are red
Violets are red
Trees are red
Post by sprsta » Wed Jun 01, 2011 7:52 pm
once the bushing wears out the short shifter will become a sloppy regular shifter
Gravelben
Post by Gravelben » Wed Jun 01, 2011 8:43 pm
m4vr1k wrote:Would you recommend purchasing one, based on your experience? I don't mind a bit of notchiness, comes with the territory.
Nope. Once the bushing fell apart it rattled constantly as well as having massive slack and crap shift feel. Come to think of it it didn't even fit either until I filed down some useless sticky-out plastic bits on the upper ball part.
You could spend a bit more and buy a decent quality shortshift, but tbh the MX5 shift action is one of the best in the business as standard anyway.
Gravelben
Post by Gravelben » Wed Jun 01, 2011 8:44 pm
sprsta wrote:once the bushing wears out the short shifter will become a sloppy regular shifter
Well it was still a shorter movement than the regular one, but mega sloppy and rattly.
Ben.Nakagawa
Post by Ben.Nakagawa » Wed Jun 01, 2011 10:33 pm
What if you transfer original bushing to the new short shifter? That's what I did with mine (different seller/bland(?) but very smiler one.
The one comes with it was not holding well The bottom one that dipping into the oil.
I did installed it on Sep/2009 and holding well. I'm just using normal daily drive and occasional touring. - read it "not hard shifting like on track".
[Edit]
PS:
I had 180 degree turn (front back) to fit perfectly. Don't know why but just a hight/position of tab hit to the large ball was bit different. Maybe because shearing with RX7 application?
So... mine has tab on back while original one was tab on front.
Ben
Users browsing this forum: Bing [Bot] and 13 guests
