Cert for turbo
Cert for turbo
I am just finishing off a project to turbocharge my '89 eunos roadster.
Can anyone recommend a good certifier in the auckland area? I know there is a list on the lvvta web page but I would appreciate recommendations.
It will also need to be certed for coil over suspension that I have added.
Having read the technical documents on the lvvta webpage I think that the car is well prepared for the cert with the exception of a driveshaft hoop. Can anyone tell me if the PPF is likely to cause problems with fitting a hoop?
Also, on the topic of certs, it's interesting to note that a change of turbo or even wastegate requires a cert... I reckon there's a lot of cars out there with upgraded turbo systems and no cert though.
Got it sorted, I had mine go around the outside of the PPF but it's basically the same
Was a real pain drilling the top of the PPF though, luckily the previous owner of my shed was a mechanic and there's a ramp outside that provides access to the underside of the car and also had to take the drive shaft out.
SLYDIT: Reading the pdf's on lvvta.org.nz it seems to have been required since at least Sept 2002.
Usually about $400 give or take. If you are on the Shore, have a talk to Neil Fraser. His contact details are on the LVVTA website.
He will normally give the car an inspection and test drive and let you know if you need to do anything.
If you can, it is usually best to get several mods certed at the same time, otherwise it can get expensive.
be aware that you need to have your car set up at the height you want the car to stay in...
they measure the ride height at certification time and you can only deviate from that by 5%...
so put in your coilovers get them all settled in and get a weel alignment THEN get the cert done...
OH and you cannot get a new wof until you have the actual steel plate attatched to the car.I got caught out as my wof ran out AFTER it had its cert done....so i had to wait for the pen pushers to process my cert and send the plate...not fun.
