NA type running rich? (tuning?)
I think my 1991 na is running rich. It has a very dirty (black) pipe and after any drive longer than 20-30 mins it leaves a black sooty film on the rear bumper. Also if I give it a go it will backfire a little when changing gear. The car runs very well and revs good but i,m sure it is running to rich.
What is the best way to solve this? Do I need to get it tuned or can I fix this myself. I dont want to put it in the garage unless I have to so I am happy to sort this out myself but am not sure where to start.
Do you still have the catalytic converter?
Usual symptoms of black around tail pipe when cat removed.
On a similar note mine has just started running lean.
I dont know why because it was fine up until a few days ago. I've got a feeling the fuel pump may be playing up as the car died at an intersection about the time it started to go lean. I've also got an rx7 AFM so i will check that is still calibrated as I set it up.
Any other suggestions for what it could be?
Pull it out & see if its burn't away!? I think there is some way to measure voltage but never done it!warrior wrote:how do i check the o2 sensor?
Also & this is a wild guess... the heat shield around your air filter? restricting oxygen perhaps???
heres some reading materialwarrior wrote:how do i check the o2 sensor?
http://mr2.com/TEXT/O2_Sensor.html
0v is lean/broken
1v super rich
make sure the car is fully warmed up
also check for vacume leaks
Briefly --- The mechanism in most sensors involves a chemical reaction which generates a variable voltage. The typical sensing element comprises a zirconium ceramic bulb, coated both sides with a thin layer of platinum. The outside of the bulb is presented to the hot exhaust gases, while the inside of the bulb is vented through the sensor body to the outside atmosphere.
A rich air/fuel mixture results in very little oxygen (O2) in the resultant exhaust gas and the difference in oxygen levels across the sensing element generates a relatively high voltage across the sensor's platinum electrodes, i.e. usually between 0.8 and 0.9 volts. Conversely a lean air/fuel mixture results in greater amount of oxygen in the exhaust gas and the output voltage runs relatively low at between 0.1 and 0.3 volts. When the air/fuel mixture is correct and combustion is complete, the output voltage runs at a mean of around 0.45 volts.
Trevor.
Checked the plug leads
