Which ITBs
Which ITBs
Post by Kieran » Fri Mar 25, 2011 2:37 pm
Which ITBs
Silvertop 4a-ge
Kawasaki ZX10
Yamaha FX
4a-ge Silvertop 1
4a-ge Silvertop 2
4a-ge Silvertop 3
Kawasaki ZX10
Yamaha FX
Post by Euen » Fri Mar 25, 2011 4:06 pm
Depends how much you want to dick around, and how much you want to spend. When I priced getting a manifold fabricated for a set of AE111 (Toyota) ITBs, the estimate was around $900 - $1000. Jenvey are now doing an off the shelf kit for the BP4W head for GBP611. (About NZD1300).
http://www.jenvey.co.uk/home/standard-k ... it-ckmmz01
There are a couple of other items required like a vacuum manifold, throttle linkage and TPS but they don't add a lot more to the price.
The other thing to remember is that you will require an aftermarket computer to drive them properly.
Post by Euen » Fri Mar 25, 2011 4:39 pm
You might also find this thread of interest
http://www.clubroadster.net/vb_forum/sh ... hp?t=39898
Post by sprsta » Fri Mar 25, 2011 4:40 pm
here is a link to a very well priced set up
http://clubroadster.net/vb_forum/showth ... GE&page=19
this should help if you go the 4age route
http://clubroadster.net/vb_forum/showthread.php?t=39898
Post by sprsta » Fri Mar 25, 2011 4:42 pm
euen you beat me to it :P
aidwano
Post by aidwano » Fri Mar 25, 2011 5:28 pm
I would say find out what diameter will suit you best. There is calculators online for working out intake diameter/lengths for what power/rpm you are after.
Getting a manifold made up may not be to much of an issue if the throttle seperation is similar to the port spacing. It is possible to cut up a stock manifold and weld a flange on, or if using the bike carbs use the rubber sleeve things.
I remember someone was selling a set of cbr 600 (?) throttles with manifold for $250 a year or so back
Post by SLYDIT » Fri Apr 08, 2011 11:32 pm
a crowd in aussie makes a manifold for dcoe carbs for the MX5.
you could use that with some Injection throttle bodies.
i think it was "injection perfection" selling the manifolds but cant be sure.
Post by sprsta » Fri Apr 22, 2011 9:12 am
12a MX5
Post by 12a MX5 » Tue Apr 26, 2011 9:08 pm
And Dont forget to explore Nissans quad throttle bodies that came out on the sr20 powered gtir's :)
Rotor Powered NA6
ITBs?
Post by Angreal » Mon Aug 08, 2011 9:16 pm
Just wondering if this would be worth sticking onto my car or will it just cause me problems/make the car worse?
http://www.trademe.co.nz/motors/car-par ... 106500.htm
Post by Euen » Mon Aug 08, 2011 10:04 pm
Hard to say. The runners look pretty short and the flares on the "trumpets" don't look that great. Probably more suitable for a forced induction set-up.
RMS
Post by RMS » Tue Aug 09, 2011 9:18 pm
I've seen quite a lot of silvertop 4age's at pick a part lately. Although most of them have been out in the weather for a while.
Post by Born_disturbed » Wed Aug 10, 2011 6:28 am
RMS wrote:I've seen quite a lot of silvertop 4age's at pick a part lately. Although most of them have been out in the weather for a while.
They tend to get taken pretty fast
