by WideOpenThrottle » Mon Mar 14, 2011 9:12 pm
Hi team...........just done a cambelt change on our other mx5,its an NB and all went well untill i it came to the 112ft/lbs of torque required for the crank bolt.
Mazda said to remove the starter motor & jam the flywheel ring-gear but i had to give it away as one bolt is impossible to get to!
Any one got any bright ideas? is there something else that works?
Gary
last_resort14
by last_resort14 » Tue Mar 15, 2011 8:43 pm
Put it in gear. make sure handbrake on. then it aint going nowhere.
by WideOpenThrottle » Tue Mar 15, 2011 8:51 pm
last_resort14 wrote:Put it in gear. make sure handbrake on. then it aint going nowhere.
Hi last_resort......tried that & had it chained to my landcruiser which had it in park & the handbrake on!
WOT
by sprsta » Tue Mar 15, 2011 9:58 pm
got a rattle gun?
zippy2
by zippy2 » Tue Mar 15, 2011 10:10 pm
have your tried to put the car in gear (2nd or 3rd) and have someone push the car backwards while you hold the torque wrench. ps I have never tried this so have no idea if it will work, just an option..
by WideOpenThrottle » Wed Mar 16, 2011 8:44 am
the rattle gun might work but i will have to take out the fans & the radiator plus the sway-bar for room but i still wont know if its at the right torque.
Maybe i should try it in reverse first.
broomfish
by broomfish » Thu Mar 17, 2011 6:12 pm
i have someone sit in the driver seat with the car in gear and the brake pushed hard
by WideOpenThrottle » Thu Mar 17, 2011 8:32 pm
broomfish wrote:i have someone sit in the driver seat with the car in gear and the brake pushed hard
Thanks Peter i may just try that.
WOT
by Growler » Thu Mar 24, 2011 2:12 pm
Thats how I did mine...
Users browsing this forum: Bing [Bot] and 17 guests
