HELP!!!! what have i done wrong!!!!!
Have replaced my shocks and springs in my NA. Shock were just a KYB replacment..slightly firmer than stock but still streetable and KINGS 30mm drop springs. The front left side of the car has dropped appox 20mm...just what I wanted but here is the problem. The right front has dropped 5mm....and the rears have only dropped 2-3mm. I have changed springs and shocks before so have a fair idea what i,m doing but have I done something wrong? Maybe a trick to lower mx5,s correctly? I have driven the car 4-5 times to let the springs settle but as you would guess I am very unhappy with this. I am going to swap the fronts around to see if the problem moves but cant see how this will fix anything. The car handles much better than before, a bit firmer but very nice. Before I go back to where I bought them from I NEED HELP!!!!!!!!
Something seriously wrong here Warrior.
I'm sure you're measuring it on a flat level surface...
Are the front springs the same length sitting on the floor, ie not mounted onto shocks?
Is the lower spring plate on the high side shock fitted fully?
Are the Shocks the same length- and similar pressure?
440HP 6.2L V8 2005 NC
Yeah...four brand new shocks and four brand new springs all the correct sizes. Measured the car in same place before and after new springs/shocks. I am very baffled with this myself. You can easliy see the diffrence between the two front struts even without a measuring tape. and basically no change to the rears from standard. anyone out there used Kings springs before with any success????
Hi - i put King springs in my landcruiser to firm up the ride and was told the ride height wouldn't change much, which is what i wanted and i can tell you now that i needed a ladder just to get my tools out the back of it.It was so close to hitting the garage door i cringed every time i went in or out!I just had to take them out again and when i rang the supplier he said i had the right ones??????????
HELP!!!! what have i done wrong!!!!! (Lowering springs)
warrior said on 14/11/10 11:24:
swapped - I've seen it happen a couple of times... the stock spring on
the front is shorter/stiffer than the rear - but not sure about your
aftermarket ones. Not sure if it will solve your side to side imbalance
though.
Hi - the possibility is that you have the front and the rear springsHave replaced my shocks and springs in my NA. Shock were just a KYB replacment..slightly firmer than stock but still streetable and KINGS 30mm drop springs. The front left side of the car has dropped appox 20mm...just what I wanted but here is the problem. The right front has dropped 5mm....and the rears have only dropped 2-3mm. I have changed springs and shocks before so have a fair idea what i,m doing but have I done something wrong? Maybe a trick to lower mx5,s correctly? I have driven the car 4-5 times to let the springs settle but as you would guess I am very unhappy with this. I am going to swap the fronts around to see if the problem moves but cant see how this will fix anything. The car handles much better than before, a bit firmer but very nice. Before I go back to where I bought them from I NEED HELP!!!!!!!!
though.
