Geometry set up
Geometry set up
Having just fitted lowered shocks and springs, 15" wheels and front and rear braces to my NA, I want to get the geometry checked/set up. Is this something that can be done by any competent tyre shop, or does it need a real specialist? Either way, any recommendations? Ideally Henderson/West Auckland.
Assuming you're not talking about corner-weighting with adjustable height suspension, any competent tyre shop should be fine.
I've had good results from my local Firestone shop who are happy to set my cars up to my specs (rather than official manufacturer specs with massive tolerances) and take the time to do it right.
I don't know if you have an alignment spec in mind already, but if not here is a basic setup:
Castor: Max (at least 4.5°)
Front camber: -1°
Rear camber: -1.5°
Front toe: 1mm in
Rear toe: 1mm in
You can experiment from there and make things more extreme if you want (plenty of people run more negative camber for track use), but its a good starting point.
PS if the shocks/springs are brand new it may pay to let them settle a bit before getting the car set up.
Front camber: -1°
Rear camber: -1.5°
Front toe: 1mm in
Rear toe: 1mm in
Gravelben wrote:More castor effectively means a greater increase of negative camber as the wheels are turned - giving you the advantage of the extra camber in the corners when you need it, without compromising the contact patch (affects braking, tyre wear etc) in a straight line.
It also results in greater stability at speed ( less darty).
