Automatic transmission gear indicator?
91 V-Spec
Post by 91 V-Spec » Fri Feb 26, 2010 3:52 pm
Does anyone out there know if the auto tranny gear indicator alongside the gearstick is meant to be backlit?
It has a dayglo spot visible through the "window" next to each letter, P, N, D etc, but that doesn't help me much at night, the cabin being as dark as the inside of a cow.
I presently have to count the clicks, and if I lose count, cautiously press the gas pedal to see what gear I'm in. Not always the safest way to find out!
Yes I know the MX5 wasn't designed for an auto, so I'm not going to complain...
'91 Eunos Roadster V-Spec
http://www.cardomain.com/ride/3837239
Grant
Post by Grant » Fri Feb 26, 2010 6:19 pm
Yes it should be lit. I used to have a '92 1.6NA Vspec auto.
91 V-Spec
Post by 91 V-Spec » Fri Feb 26, 2010 6:46 pm
Thanks, it is worth pulling the console apart then!
Sick of having to use my phone screen to check it... I wonder if that's illegal now too?
Post by sprsta » Fri Feb 26, 2010 7:09 pm
i just did a manual conversion last weekend this is the bulb you want to replace
ps i have an auto gearbox if anyone wants it or itll go into scrap
91 V-Spec
Post by 91 V-Spec » Fri Feb 26, 2010 7:31 pm
Ah brilliant! Is it as hard to access as it looks like it is?
Post by sprsta » Fri Feb 26, 2010 7:37 pm
not once you take the consol out
if you stop in at my work on monday i can change it for you
bodyworks panelbeaters
73 wakefield st
auckland CBD
ask for cole if i dont see you
91 V-Spec
Post by 91 V-Spec » Fri Feb 26, 2010 7:47 pm
Oh perfect, only a few blocks from my work! Hang on, I'll PM you...
91 V-Spec
Post by 91 V-Spec » Mon Mar 01, 2010 9:57 pm
Thanks for that mate!
Definitely a lot less hassle than replacing it myself!
Ten points and a blatant plug for Cole at Bodyworks Panelbeaters!
