Gearbox gaiters
Gearbox gaiters
Post by WideOpenThrottle » Sun Feb 14, 2010 5:39 pm
Just trying to fit new gaiters but cant detach the gearstick base from the shaft to enable the the old to come off.
I have the gearstick out & in the vice but it seems to move only slightly & feels rubberised.
Is it a case of twisting with brutallity or am i overlooking the obvious? :D
Gearbox gaiters
Post by poison » Sun Feb 14, 2010 5:50 pm
STOP....
Just cut the old one off. And even though it doesn't seem possible, the new
one will slip down over the shaft with some oil. If it's an NA don't forget
you need to add oil into the top as it's a separate area to the gearbox
itself.
Post by WideOpenThrottle » Sun Feb 14, 2010 6:59 pm
Cheers Poison-i will give it a go!
Post by Habanero666 » Sun Feb 14, 2010 7:56 pm
add oil to a NB 5 speed as they also have seperate oil in the shift turret.
Gearbox gaiters
Post by poison » Sun Feb 14, 2010 8:14 pm
Honto? Someone told me it was separate on the NB, can't trust anyone :)
Post by WideOpenThrottle » Sun Feb 14, 2010 8:30 pm
Just how much should it take?
Post by Euen » Sun Feb 14, 2010 9:28 pm
90cc or until full
http://www.miata.net/garage/trans/28.htm
The garage on Miata.net is full of handy bits of info like this.
Have fun.
KSCRIM
Post by KSCRIM » Sun Feb 14, 2010 9:29 pm
From Miata.net Garage
Shifter boot replacement instructions
by Pat Voigtman - voigtman@execpc.com
This job should take about 30 minutes. The only tools needed are a #10 socket, a Philips screwdriver, a knife, and three ounces of gearbox oil (75W90).
1. Order two new shift boots (lower and upper) from Roebuck @ $15/each.
2. Unscrew the shifter knob.
3. Remove the plastic console from between the seats. There are five screws, one on each side of the front, one under the ashtray, and two by the fuel tank release knob. Be careful when removing as there are wires attached near the passenger front side. Unhook these wires.
4. Remove the isolation on top of the shifter.
5. Remove the four bolts (#10) holding the upper shift boot. Remove the old boot.
6. Put the car in neutral.
7. Remove the three bolts (#10) holding the lower shift boot.
8. Lift the shifter (and lower boot) out.
9. Remove the lower shift boot from the shift lever. You may have use a knife to cut it off. Look at the new one before cutting off the old (you don't want to cut off too much.)
10. Put a little bit of gearbox oil on the shift lever and slide the new seal on. It goes on VERY hard. FYI - There is a nylon o-ring that needs to be put back on BEFORE the lower seal goes on.
11. If there is any oil in the turret (it was dry in my 90), use a turkey baster to remove it.
12. Refill the turret with 3 fluid oz (about 75 - 80ml) of new oil (gearbox oil). This will fill it up about half way.
13. Replace the shift lever. Notice the indent on the front (on the ball portion). This indent needs to line up with the front of the car.
14. Replace the upper shift boot.
15. Replace the plastic console
Drive around the block and see if it shifts any easier.
Note:- 5speed has oil in turret, 6 speed - NO OIL in turret. Use Gearbox oil, 75-9o GL4
Post by WideOpenThrottle » Mon Feb 15, 2010 6:38 pm
Thanks to all-it all went smoothly :D
