My car has always had a slight hesitation when revving from cold...it seems to dissapear when hot. You can feel it as a change in acceleration regardless of throttle position (seems to be around 2500 rpm but isn't consistent)
Leads, plugs and airfilter are new. A bottle of injector cleaner was put in not so long ago.
Any ideas? (AFM needs a clean?)
Slight hesitation when revving...what could it be?
Also, has anyone installed one of the roll bars from Dons Autoway services from Hamilton?
He indicated that there would existing bolt holes behind the seats- There is one on each side which doesn't seem to line up with the plates on the bar?
Im also curious to see what people did re trim? Install over the carpets?
Pictures of how it bolts to the seatbelt towers would be useful too
Yeah! i would clean your AFM as well as the throttle body internals with CRC airflow meter cleaner{let the stuff fully evaporate before engine start-up.]
Also a mate of mine just had his Mazda Familia do similar things & it turned out to be the inlet hose to the throttle body had cracks along the plastic ribbing alowing air to pass so fooling the AFM.
