How to Rebuild a 1600cc Mx5 Engine?
Nope, IMHO maybe half of what you spend and forget about the labour. At the same time it's really rewarding to do something yourself, but as I said before it needs to be something you will use and keep otherwise a project without a solid goal will never get completed. Nothing beats driving your car and knowing you did the mods yourself. So think more about where you want to go with it, I think it's a good goal to rebuild a motor if you are going to use it.andyling wrote:Ok, I give up the turbo idea for now,because I'm scared
What if I buy a 1.6 Engine, and rebuild it, and sell it.
Would I get my money back(not including labour)?
Re: 250whp
Anthug wrote:You can find on Flyin' Miata's website www.flyinmiata.com who sell turbo kits and have been around for 25 years the following:
1990-93 FM II Hydra turbo system
The FM II is a legend in the Miata performance world, and this is the latest and most powerful version. Expect approximately 230 hp at the rear wheels at 12 psi, compared to a stock 93 hp. Driveability is excellent and there`s no need to even remove the valve cover. Expect years of reliable high performance with this system. More power is available on built engines.
1994-95 FM II Hydra turbo kit
The FM II is a legend in the Miata performance world, and this is the latest and most powerful version. Expect approximately 265 hp at the rear wheels at 12 psi, compared to a stock 100 hp. Driveability is excellent and there`s no need to even remove the valve cover. You`ll get years of reliable high performance with this system. Even more power is available for built engines - we`ve seen well over 300 hp.
It all depends on what your goals are. You are wasting your money otherwise.
Yes and I have lots of those miracle wrinkle creams and instant ABs machines too.
America F yeah....
Habanero666 go to bed you're bored aren't you...lol
Re: How to Rebuild a 1600cc Mx5 Engine?
poison wrote:Habanero666 go to bed you're bored aren't you...lol
Just had a nice rest, still an angry Scotsman....
He must live in Alaska, it's a stock MX5 radiator...
OK OK mister picky
I was merely inferring it must be somewhere a wee bit
chilly given the stock radiator...
Yeah I saw the SU's too, the Brits just love them. Most likely a Rover or
P76 engine, I think that was the first alloy block V8 in the UK.
I thought parts would be still plentyful? They have developed the Rover engine for many years so I would say there would be plenty of performance parts available. Do they still use them in the TVR's?brownie wrote:Looks like a Rover 3.5 V8 to me,Must admit the thought has crossed my mind one or twice ,Just getting a bit hard to find bits nowdays.
Nice little light weight motor with a good sound
The engine is a Ford V8 (with Edelbrock heads).
As shown here http://www.peeble.com/rubbish/nr06.htm
The Daimler 2.5 V8 preceeded the Rover by quite a few years and I'm pretty sure that was an alloy block. (edit - looks like I may be wrong, seems it had alloy heads but I can't find any reference to the alloy block) I'm sure someone will correct me if I'm wrong. The "Rover" V8 was in production as a GM/Buick engine before Rover bought the rights to it so doesn't really qualify as British.poison wrote:Yeah I saw the SU's too, the Brits just love them. Most likely a Rover or P76 engine, I think that was the first alloy block V8 in the UK.
I initially thought the picture was a Rover as well. The inlet manifold looked like the Rover one. But the Distributor didn't look right.
Rover V8
You are right http://en.wikipedia.org/wiki/Rover_V8_engine
First line The Rover V8 engine is a compact V8 internal combustion engine with aluminium cylinder heads and cylinder block
It turns out the Leyland P76 came out in 1973 and had the 4.4L Rover V8, I
always thought it was a different engine.
End of the day it's a Rover V8 3.5,
Anthug,They are wrong,Dizzy is in the wrong place for a ford V8.
I had one of these motors year ago when i bought a cheap Rover V8 P6B car for the motor to go into a Capri,Weigh about the same as a old Pinto 2lt motor.
Found a bit of info on the net about putting one in a MX5,Poms make it look to hard,If you can jam a 1uz in,a little 3.5 V8 can't be that hard (Famous last words?) .Stick with my B6 ,Least i can get bits for it if i kill it.Which i doubt.
