Ever since I put this in and second day of drive, it start rattling very badly.
I had replaced gear gaiter (rubber boots) other day and it was still in the bin. I picked up and cut up the thick part of rubber and warped the shaft ( actually put in to the knob).
It made pretty tight fit and I also used blue thread locker to the three alen screws at base.
I have read someone in US actually using fuel line to do similar trick.
I'm hoping it will hold this time.
next time I want to change the interior scheme, I will go something more easy/effective option like one made for MX5.
Momo Shift Knob
Momo Shift Knob
Ben
This anchor screws comes loose very easily.
A resin solution sounds very good. I will try if this did not hold longer. Thanks for tips.
Another possible source would be a some of those worn bush in the shifter itself. If I re tighten the anchor screws, noise will go away for while. So, I'm kind a ruled out this but I may come back to this route as well.
Ben
It's holding well so far, it's still tight.
BTW, the source of the noise was loose clip around the centre console surround. the one that surrounding stereo unit.
I took it out (and installed storage pocket under the head unit), I filled the epoxy glue to the hole that holding a clip and refit them.
No annoying noise so far.
Ben
