Are after market components available as is the case with some cars?
Has anyone made this modification and if so what were the results?
Advice will be much appreciated.
Trevor.
You could always manufacture solid mounts for them yourself.Trevor wrote:Sincere thanks, but I am well aware of these options which are not in line with my requirements.
A tactile message via the steering is what I am after. With that in hand, all else is correctable and adds to the fun!!! N.B. I do not lack experience relative to motor racing, including a time when sticky tyres had not spoiled all the fun!!!
Cheers, Trevor.
I have never had issues with the steering at all so have never pulled the rack etc apart.Trevor wrote:There is no movement/play as such and I simply wish to eliminate any tendency towards a spongy feel.
I intend to check exactly where shock absorbing has been incorporated between steering wheel and beyond, but had hoped someone might have previously tackled this and recorded prior experience.
Thanks, Trevor.
Motor racing wasn't ruined....we just went faster!!Trevor wrote:Great, when sticky tyres arrived on the scene, motor racing was ruined.
Most modern race cars (including Formula 1) do drift going around a corner. It's just that with todays technology it isn't as obvious as a 60's F1 car (Good 'ol Lotus 49B comes to mind!!).Trevor wrote:Growler, while growling, please post a photo of a modern "racer" in a four wheel drift. N.B. Stupid drifting does not constitute a motor race!
I'm not even going to start to interpret this one!!Trevor wrote:Be sure I require no instruction regarding that which is simplistic.
Mika?Trevor wrote:please post a photo of a modern "racer" in a four wheel drift
I'm sure nobody is saying you do, or is trying to second guess your existing knowledge of MX5 suspension setup. They are just asking questions to try and help with you original request. How can people help you if they don't know what outcome you are trying to achieve?Be sure I require no instruction regarding that which is simplistic.
