Trevor
by Trevor » Thu Jul 26, 2007 2:47 pm
I am looking for a steering column switch assembly for a 1997 1800, i.e. the unit incorporating the control stalks.
Does anyone know of a wrecker who might have one, or any other possibility? I have found plenty for the 1600 series, but none suitable for the 1800, which is different.
Any help will be much appreciated.
Trevor.
by SLYDIT » Thu Jul 26, 2007 4:56 pm
Any particular reason you need a new one?? May be able to be repaired??
Trevor
by Trevor » Thu Jul 26, 2007 5:03 pm
Yes, there is a particular reason. I have fitted a smaller much flatter wheel to permit a straight arm driving position and wish to modify the switch stalks to suite.
Trevor.
Trevor
by Trevor » Fri Jul 27, 2007 10:14 am
Thank you David, very much appreciated.
As it happens I had seen the item on Trademe, having considered that possible source. Unfortunately the car involved is a 1600.
Cheers, Trevor.
Trevor.
Trevor
by Trevor » Fri Jul 27, 2007 5:25 pm
Thanks Gerry, much appreciated.
I did try MX5 Mart some time ago and experienced nothing but frustration. Even so I have sent another enquiry.
Trevor.
