Brakes Problem
Archives of Posts to the NZ MX5 List back in 2000
john.bayliss
Brakes Problem
Post by john.bayliss » Wed Dec 20, 2000 11:21 am
I have recently had two incidents on my 89 Eunos of the drivers side rear brake
sticking. On the second occasion it was really bad and within a few metres was
getting very hot and smoking.
Mechanics have stripped the brakes down, cleaned them and replaced the pads, but
were unable to find the cause.
Has anyone had similar problems? What was the solution?
John
______________________________________________________________________
nzhelpdesk@aon.co.nz
The information in this email and in any attachment(s) is confidential. If you
are not the named addressee(s) or if you receive this email in error then any
distribution, copying or use of this communication or the information in it is
strictly prohibited. Please notify us immediately by return email and then
delete the message from your computer. While attachments are virus checked, the
Aon Group of Companies do not accept any liability in respect of any virus which
is not detected.
Peter Sweetman
Brakes Problem
Post by Peter Sweetman » Wed Dec 20, 2000 1:02 pm
Try the handbrake mechanism sticking and not releasing properly. If it is
knackered they can be resleeved if not too bad
It is probably the problem...
Gary Morrison
Brakes Problem
Post by Gary Morrison » Wed Dec 20, 2000 5:18 pm
When I stripped my brakes down the slider pin on the right rear caliper was
rusty and sticking a bit. I replaced it, wasn't expensive... I can't see
what else would cause it to stick. Are you sure they actually dismantled the
caliper when they did the job?
Gary
ian cole
Brakes Problem
Post by ian cole » Wed Dec 20, 2000 5:43 pm
The sliding pins can be cleaned with fine emery tape and lubricated with
copper anti seize paste, this should last quite a while. Ian Cole
At 17:18 20-12-00 +1300, you wrote:
H & J Weir
Brakes Problem
Post by H & J Weir » Thu Dec 21, 2000 12:00 pm
I have also experienced the non-releasing rear brakes.
In my case it was a non-complete release of the hand brake. This was fixed on
the road-side by jiggling the hand brake pivot at the calliper (car in gear,
brake off) and at the workshop by stripping and lubing the pivot assembly.
I might add that it took a little effort with lubing the slide bolts etc
before finding the real cure.
One of our local mx5 group members has experienced two rear brake fires as a
result of incompetent brake servicing (neither too serious)
Howard W.
Return to “2000”
