Does anyone one know where to source;
a) 2 new rear KYB ref # 341127 &
b) 4 shock rubber boots for a good price.
... or even another 'ggod' brand of rear shocks
Perry
KYB shocks & shock boots
Perry
Perry
Hi Perry,
You can just use some universal shock boots and trim them to suit from any
of the usual auto parts stores.
Anthony.
Anthony.
Perry
I fitted KYB's to my 5 and I like them. They are KYB-AGX adjustable, via a
knob on the side. Part Numbers: Front NSL 741015 - Rear NSL 741016. I got
mine through TWL (Transport Wholesale Ltd) Sorry can't remember the price,
not cheap but very good for road work. Boots, I would only use Mazda parts
as the boot has an in built 'bump stop'. Mazda only stock rear ones as they
think that the front are the same but the bump stop is a different height.
You would have to order front ones from Japan. When I did mine the only boot
that needed changing was the rear left which I presume was because it is
below the fuel tank over flow, can't put it down to any other reason. KYB
site is worth a look www.kyb.com or got to the catalogue at
http://www.kyb.com/catalog/
NB: Part Numbers are for a 1996 NA
Good luck
Wayne
Good luck
Wayne
What springs did you use with them Wayne?
