Cam belt
Janet & Jeff Curtin
Cam belt
Post by Janet & Jeff Curtin » Mon May 24, 2004 4:25 pm
Don't know about Auckland but do shop around, I have had quotes from 2 to
5 hours labour"""
Cheers Jeff.
Listen to music online with the Xtra Broadband Channel !
Colin Francis
Cam belt
Post by Colin Francis » Mon May 24, 2004 4:55 pm
On Mon, 24 May 2004 04:25:58 +0000, you wrote:
<html><div style='background-color:'><P>Don't know about Auckland but do shop around, I have had quotes from 2 to 5 hours labour"""<BR><BR>Cheers Jeff.</P><BR><BR><BR>
<P dir=ltr style="MARGIN-RIGHT: 0px" align=left>&nbsp;</P></div><br clear=all><hr>Listen to music online with the <a href="http://g.msn.com/8HMBENNZ/2749??PS=47575">Xtra Broadband Channel</a> !</html>
Any chance of you doing the decent thing and post TEXT emails instead of the
HTML variety ?
Colin Francis
Krenford Holdings Ltd
P.O. Box 18547
Christchurch
New Zealand
www.westmorland.co.nz
Perry perry
Cam belt
Post by Perry perry » Tue May 25, 2004 1:10 am
You may wish to consider other work that may be required to be carried out
at the same time.
As I had my cambelt replaced along with; @115,000 km
1. belt tensioners rollers
2. all the seals
3. all the other belts
4. rad. hoses
5. the water pump as if it failed in the future you still would have to
remove the cambelt to access
the pump.
.. and had the front discs replaced and the seized rear brakes repaired
and bleed.
That costed $1,500!!! major budget blow out. The quote for just the cambelt
only was approx $500.
But at least it was a job well done, and no one complains about good quality
workmanship...
remember... if it's cheap... will they know of the associated problems with
earlier NA models which had camshaft failure as a result the incorrect
manner a certain 'pin' is re inserted the wrong way around?
GrubbyMX
Cam belt
Post by GrubbyMX » Thu May 27, 2004 11:28 pm
While we are at it any chance of you replying with the new text at to top of
the Email string Colin?
Ralph
Keith
Colin Francis
Cam belt
Post by Colin Francis » Fri May 28, 2004 12:21 am
Ralph
I trust you know more about MX5s than you do about email protocol.
They are not email strings. In email groups they are called threads. THe only
reason why many post at the top is because Microsoft have so dictated in their
lame Email clients to do so thus moving away from the Email convention.
Html postings are also frowned upon in most email groups. Security wise it is
not wise to use html either.
Only too happy to educate Ralph. :)
GrubbyMX
Cam belt
Post by GrubbyMX » Fri May 28, 2004 12:28 am
Sorry to be so iggerant colin, I will go back to my box
Isn't a string a thick thread?
Keith
Colin Francis
Cam belt
Post by Colin Francis » Fri May 28, 2004 1:40 am
Ahh. The vagaries of our language. LOL
Col
In a mausoleum colossol,
the explorers uncovered a fossil
that they could tell by the bend,
and the knob on the end,
'twas the peter of Paul the Apostle
Lyndon Pope
Cam belt
Post by Lyndon Pope » Fri May 28, 2004 5:20 pm
I was a Computer Engineer for twenty four years. Started on mainframe about
1978, got out a couple of years back when the little PCs became so
mind-numbingly boring. So I feel suitably qualified to make the following
observation about the text below. 'Strings', 'threads'... who cares!!
Cam belt
Post by poison » Sun Dec 12, 2004 8:40 pm
Hi Perry
Can I ask who did the Cam belt please? (if in Auckland),
Janet & Jeff Curtin
Cam belt
Post by Janet & Jeff Curtin » Sun Dec 12, 2004 9:04 pm
Yep Perry is correct, I forgot about the tensioner pulleys , I got my
done at the same time, a good price from " Road and Track " in Lower
Hutt, {ask for Kevin ,tell im Jeff sent ya lol} and "Collins auto parts"
also in the hutt will do the seals etc at a good price, {ask for Dennis
tell him you are an mx5 member} .
I just checked my receipt for work done it was $270.00 labour including
gst for 6 hours work to do the whole front end basically ie: belts,
seals, pulleys, pump etc.
Cheers Jeff.
Perry perry
Cam belt
Post by Perry perry » Mon Dec 13, 2004 6:16 pm
Hi Gazza
I used Mt Eden Motor & Panel Services, 488 Dominion Road Mt Eden Ph
630-2213. Murray's the owner & still remembers working on my car...
probably because I photocopied all the info re: cambelt replacement and
potential problems.
Tom, the owner of Auto Clutch recommended him after he sorted out some
cambelt problems for him. I have to admit I paid more than I expected but
no one ever complains about a quality job.
The only thing I have to sort out is how to adjust my fuel air fix as the
MX5 is running a little rich, gauging on the blacken spark plugs. Any
pointers???
Mikkels
Cam belt
Post by Mikkels » Wed Dec 15, 2004 7:11 pm
Hi
There is no easy way to adjust your mixture. If your O2 sensor is good then
you need to suspect your Air Flow Meter (AFM) calibration. I'm assuming
your air filter is good and that you are not burning oil which may make your
plugs black. The best measure of your mixture setting (gross) is your fuel
consumption. Are you getting the mileage you should? MX5 is not that
economical so you need to ask around to see what you are getting for your
type of driving for your model.
The 1.6 AFM can be adjusted but need to be done with the assistance of a
dyno.
Don't leave the problem as a truly rich mixture will wreck your bores.
I have a device that is made from a Jaycar kit it will give you a rough idea
of mixture.
I'm in Auckland. Email if you want help.
Don
Perry perry
Cam belt
Post by Perry perry » Thu Dec 16, 2004 5:42 pm
Thanks Don
Maybe I could meet up sometime overthe break.
I assume the O2 sensor is OK.
I have just installed a Jamex foam filter & have new split fire spark plugs.
(Could the plugs be too hot/cold?)
I do mainly very short trips as I only live 5 km from work so I get only
400km out of a tank (1600 cc 1991 model)
Perry
To: "'MX5List'" <mx5list@mx5club.org.nz>
Subject: RE: Cam belt
Date: Wed, 15 Dec 2004 19:11:28 +1300
Hi
then
your
your fuel
dyno.
idea
of mixture.
Don
Perry perry
Cam belt
Post by Perry perry » Thu Dec 16, 2004 5:59 pm
I assume it's the original sensor... 1991 model
Perry
Subject: Re: Cam belt
Date: Tue, 14 Dec 2004 10:48:22 +1300
how old is your oxygen sensor?
Alternatively your airflow meter can be 'recalibrated' - I think Don
did some tinkering in this area ..?
Jeff.
the
pointers???
_________________________________________________________________
Is your PC infected? Get a FREE online computer virus scan from McAfee.
Security. http://clinic.mcafee.com/clinic/ibuy/ca ... p?cid=3963
Mikkels
Cam belt
Post by Mikkels » Fri Dec 17, 2004 8:51 pm
Hi Perry
I'm sure your O2 sensor will be fine and 400 per tank is great for round
town running. My 1.8 conversion only get 300 for around town and the
mixture is verified as being OK on the Dyno.
I would suspect your plugs. Modern unleaded fuels do not produce a white
exhaust. Soot is all you get out the back. Yep I'm around over the break
so Email me if you want some help.
Don
Return to “2004”
