Hi All
The heater in my car is no where near as good as it was six months ago. I
crawled under the dash and stuck my head into the clutch peddle to check the
linkage control on the hot box last night, but all looks OK.
Does the Heat Control Lever control the water flow in the hot boxes radiator
OR, the air flow through the hot box?
What is the best way to flush the heating radiator, preferably without
ripping the entire dash off to get it out?
Adrian
Disclaimer:
The information in this electronic mail message is confidential and may be legally privileged. It is intended solely for the addressee. Access to this Internet electronic mail message by anyone else is unauthorised.
If you are not the intended recipient, any disclosure, copying, distribution or any action taken or omitted to be taken in reliance on it is prohibited and may be unlawful.
When addressed to our clients any opinions or advice contained in this Internet electronic mail message are subject to the terms and conditions expressed in the governing KPMG client engagement letter.
KPMG accepts no responsibility for any effects this email message or attachments has on the recipient network or computer system.
Heater problems
Heater problems
air flow thru the hot box.
The hoses going from the back of the head thru the
firewall to the heater should be fairly hot if you
give them a squeeze after warming the car up.
Normally people have too much heat, not too little !
Heater problems
Thanks. I guess I'll have to pull the box out if the hoses are hot. The
engine heats up fine and has a new thermostat and coolant ( less than 6
months old )
Adrian
months old )
Adrian
Heater problems
hmm... are you saying that your heater isn't as good
as 6 mths ago *and* your thermostat was done then ..?
looks like a smoking gun from here ...
I've noticed that while the temp gauge takes 4-5
minutes to reach the 11 o'clock position, it doesn't
fully warm up the coolant for another few minutes.
IOW, "normal" on the temp gauge is anything between
about 65-100 C. (cross-referenced with Link temp
sensor)
sensor)
Heater problems
Good point. I don't tend to notice the performance of the heater as I dress
up warm and the wind blows away any heat in the car.
The mechanic was replacing my cam belt and said the thermostat was upside
down. Which way does it go? I might pop the pump top and have a look. Spring
down? Or I need a hotter thermostat.
Adrian
Adrian
