SC
Grant Schou
SC
Post by Grant Schou » Tue Jun 10, 2003 8:58 am
Hi, looking for supplier of a check valve to insert in the 1/2"line between my air intake on my supercharger and the air inlet on the dummy throttle body - supposed to get an extra 1/2 psi boost .
Any help ?
Grant
rotarypower
SC
Post by rotarypower » Tue Jun 10, 2003 9:00 am
ash air has them on the shore >glenn munro
Grant Schou wrote:
lou Girardin
SC
Post by lou Girardin » Tue Jun 10, 2003 3:35 pm
I used a 1 way valve from a Chev ex- wreckers or you could try Ash Air Ltd in
Auck.
SC
Post by SLYDIT » Tue Jun 10, 2003 5:45 pm
"Hose supplies" has them as well. You can get brass
spring loaded check valves very cheaply, just check
that the spring is not too stiff. if it is then you
can simply unscrew the two halves and cut the spring
slightly to make it more forgiving.
Glenn
--- rotarypower <rotarypower@value.net.nz> wrote: >
Any help ?
Grant
This email contains confidential information. If
you have received this
email in error, please delete it immediately, and
inform us of the mistake
by return email. Any form of reproduction, or
further dissemination of
this email is strictly prohibited.
Also, note that the opinions expressed in this
email are those of the
author and are not necessarily those of the
Fonterra Co-operative Group
Return to “2003”
