Do you recommend higher octane for 14 degree timing ?
Mike Pearson - WYSIWYG...
Post by Mike Pearson - WYSIWYG... » Thu Sep 26, 2002 10:07 pm
Hi, I did a search for "advanced timing" on the NZ lists,
but didn't find any discussion.
What are people's experience with running 91 or 96 Octane
with the timing set to 14 degrees ?
Mike - 1990 Eunos Roadster - WYSGUY
www.eunos-roadster.com
Post by zorruno » Thu Sep 26, 2002 10:39 pm
sorry I think the database was re configuring at the time. There are about
100 hits for timing advance now.
PS - I run 96, and 16 Degrees - occasional detonation if I ever run 91
jeff
Post by jeff » Thu Sep 26, 2002 10:52 pm
it's more likely, but not guaranteed, that you'll need
more octane with the timing bump.
If you're like me and want the most bang for your buck
(ie stay w/ 91 octane), after advancing if it pings
just dial it back a little until it stops pinging.
Scribe a pencil mark across crank angle sensor
beforehand so you know where to set it back to if
necessary! I had to resort to this deviousness since
I never used a timing light ...
Post by Mike Pearson - WYSIWYG... » Thu Sep 26, 2002 10:56 pm
Thanks zorruno,
I did the search again, and found a posting from you was just what I was
looking for:
-- Original post --
Most people report that advancing the timing to 14 degrees still allows the
use of 91 octane without problems. Mine is at around 16 deg and I find that
I have to use 96. Others (Gary M?) have used an 18 degree setting in the
past and I assume 96 octane?
Also, thanks to Gary Morrison for a nice dyno graph too.
Seems to show the advanced timing kicks in at about 3,000 rpm.
Return to “2002”
