ABS
Phil McArthur
ABS
Post by Phil McArthur » Mon Sep 09, 2002 6:04 pm
I was looking lovingly under my bonnet today and noticed that on the fusebox
between the fuses marked 'cooling fan' and 'BTN' is one marked 'ABS', (in
brackets.) Sure enough there is a fuse under the cover (60A). At the risk of
sounding thick I am forced to concede that I don't know if I have ABS, and
wouldn't know the relevant under bonnet componentry to look at if it leapt up
and hit me in the face. The sticker inside the drivers door has N under ABS,
but then it also has N under aircon, and it certainly has that! How can I
recognise and ABS setup under bonnet, and what year was this first available
as an option? Or is there a simpler explanation for this?
ABS
Post by biff » Mon Sep 09, 2002 6:43 pm
Yep!
lou Girardin
ABS
Post by lou Girardin » Tue Sep 10, 2002 8:11 am
MessageThere is a high pressure pump under the bonnet linked by brake lines to
the master cyl.
Lou
Return to “2002”
