Exhaust
Exhaust
I have access to a 2.5" Mandrel bent exhaust for my mx5 (off a tubo MX5), My
cuurent exhaust is the standard one with the cat converter removed and a
turbo muffler to reposition spare wheel.
I was wondering whether changing to the 2.5" exhaust is going to make a
noticable difference or if it is worth while doing at all
Cory
Cory
Exhaust
Theoretically I think 2.5" is too large for a normally aspirated car. 2" is
usual. Theory would have it that at 2.5" you lose some exhaust gas velocity,
and hence power. That right Fletch?
Exhaust
Cory <cory@lakelandsteel.co.nz> wrote: Two and 1 half inches is too large a diameter for a N/A MX-5 engine
Cory
Cory
Exhaust
yes , it's to do with 'scavenging' exhaust fumes.Maintaining desireable back pressure prevents exhaust fumes re-entering the head, via exhaust valves(open) during de-celleration and gear changes when exhaust pressure/velocity drops...
Gary Morrison <gm@paradise.net.nz> wrote: Theoretically I think 2.5" is too large for a normally aspirated car. 2" is
Exhaust
I've got a 2 1/4 inch exhaust and no cat. It definitely made a
difference but from what I've been told, 2.5 might be a bit to large and
you might get a bit of "cackle" noise (although some people like this).
Only problem for me is now, I've changed the timing as well and advanced
it a couple of degrees and I think it's running a little rich as someone
else mentioned a while a go and is also "painting" my bumper. What's the
best/easiest way to adjust the mix?
Exhaust
Actually I think its the velocity creating a vacuum effect which scavenges the
exhaust fumes. A larger pipe has lower gas velocities and the momentum in the
flow is not as high... Also in a well designed extractor the resonances in the
tubes assist with the same thing, again, as I understand it.
Exhaust
from my extensive net surfing experience, I gather that diameter/length is more critical in the exhaust manifold runners down to the collector, where the pipes, uh, collect. You don't want oversized pipes here for the reasons Gary mentions.
The stock exhaust pipe (ie after exh.header) however is < 2 inch diameter, with some yukky bends around the rear axle. A mandrel-bent system will definitely be better than stock. Big pipes here shouldn't hurt your torque curve much if at all. If you search miataforum there's some discussion about this.
and yes, "yukky" is a technical term
Exhaust
This is what I understand too...
My recollection is that the "optimum" size for a 1.6 is 2 1/4 " and for
1.8, 2 1/2" ...
So, if you've got a 1.8, its fine... It would still be worth trying...
might be a better compromise than the stock one?
Its only held on by two bolts and some rubber hangers, so it wont take long
to try it...
1.8, 2 1/2" ...
to try it...
Exhaust
Speaking of exhausts... what's the effect of removing the catalytic
converter
i'm assuming mine has one as it was imported at the end of last year.
wasn't the weather fantastic over the weekend? i drove up to Leigh for a
couple of days and had the top down the whole time... a bit chilly
but worth every minute... roll on summer!
mike_y
converter
mike_y
