Eunos Roadster
Fr.Wayne
Eunos Roadster
Post by Fr.Wayne » Tue Mar 26, 2002 8:13 pm
Hi
I am a new member and I drive a Eunos Roadster 1990 vintage. When starting the
car after the engine has heated up there is a loud tappet noise which only
goes after the oil gets to the top end. This car has a 1600 motor. Is this a
common problem with these engines or is there a problem there?
Also there are two fans side by side at the front of the engine. The left one
does not appear to work. Is this a backup or are they both supposed to work at
the same time?
I would appreciate feedback on these questions when you have the time.
With thanks
Wayne
Graeme Naisbitt
Eunos Roadster
Post by Graeme Naisbitt » Tue Mar 26, 2002 8:34 pm
Hi Wayne,
No its a very common problem. Hydraulic lifters... it can be cured though,
apparently as I've never tried, by several methods. The usual being to
change the viscosity of the oil. But be reassured that negligible damage
will be done. Check out some of the other very good sites around or do a
search here! A good one to look into is http://www.miataforum.com and
another is http://www.miata.net ... :)
Graeme
D4NGER
Michael Donovan
Eunos Roadster
Post by Michael Donovan » Tue Mar 26, 2002 8:51 pm
As far as the fans go, if you have 2 of them you'll have aircon fitted. If you
are standing "IN FRONT" of the car facing the fans, the right one is the
normal engine cooling fan and the left one is an auxillary fan used to provise
additional cooling when the air con is operated.
Mike
Mark Roberts
Eunos Roadster
Post by Mark Roberts » Wed Mar 27, 2002 7:56 am
starting the car after the engine has heated up there is a loud tappet
noise which only goes after the oil gets to the top end.
Perfectly normal. Gets better when you have an oil change...
McInnarney, Brendon (B...
Eunos Roadster
Post by McInnarney, Brendon (B... » Wed Mar 27, 2002 8:11 am
Use Genuine Mazda engine oil part number K200W0528M4 this stuff works wonders!
Return to “2002”
