my2cta
by my2cta » Mon Mar 04, 2002 8:22 pm
No eardrums either Scott
Tim Dutton
MY2CTA
Tim
MY2CTA
Ross and Meg
by Ross and Meg » Mon Mar 04, 2002 8:26 pm
Where do you put the sink Tim ?
89MX5
Graeme Naisbitt
by Graeme Naisbitt » Mon Mar 04, 2002 8:26 pm
Hmmm, I've lost 80% of boot space fitting the amps, now I'm going to lose
the parcel shelf to two 10" Sub Woofers ...
my2cta
by my2cta » Mon Mar 04, 2002 8:27 pm
The boot is a bit bigger in volume and more "packable" due to better
arrangement of the space - both battery and spare wheel are under a flat
floor that stretches from one side of the car to the other - much more
amenable to packing a lot of stuff. It isn't as tall in the middle where
the M1 boot has the deeper well, but I haven't found that to ever be a
problem.
If I want to carry big or heavy stuff I use one of the other cars, e.g. the
Vitara towing the horse float to collect 35 bales of hay... Can't even fit
one in the MX boot
Tim Dutton
MY2CTA
Tim
MY2CTA
Scott Elder
by Scott Elder » Mon Mar 04, 2002 8:41 pm
No, my ear drums are semi-safe untill I get a newer, more powerful amp to
run it
It's only cranking out about 200w @ the moment
Scott Elder
by Scott Elder » Mon Mar 04, 2002 8:43 pm
I've already lost that room to the 6x9's
what subs r u putting in?
Scott Elder
by Scott Elder » Mon Mar 04, 2002 8:44 pm
Official MX5 Club Member Statment
"Anythings possible"
Fletcher Blades
by Fletcher Blades » Mon Mar 04, 2002 10:36 pm
Official Mazda policy statement - "This car is not suitable for towing".
Tim Dutton
MY2CTA
Generally, I try not to have to tow any car I own, but if it needs it,
I'll do it, no matter what the manual says...
Fletcher Blades
by Fletcher Blades » Mon Mar 04, 2002 10:37 pm
I've got a set of good quality 6X9's that I removed from my previous
car, but I've never figured out where I could put them in the MX-5...
Where are yours?
peter
by peter » Mon Mar 04, 2002 10:58 pm
Official policy? (deep breath... ) from Mazda? they still haven't worked out how to put lights behind the cheap plastic
bumper reflectors...
Peter
DRGN1 +trailer
P.S I also (on occasion) ignore Official Policies on speed, noise, amount of passengers, being happy in the rain, and
excessive amounts of chrome...
Graeme Naisbitt
by Graeme Naisbitt » Mon Mar 04, 2002 11:02 pm
Don't know until I can afford them
Looking around now, but I'm also
putting a laptop in to play mp3's and thats turning into a money pit...
carl.halvorsen
by carl.halvorsen » Tue Mar 05, 2002 6:57 am
My MX has lights in the bumper reflectors, Mazda OEM ones!
Carl
Mark Roberts
by Mark Roberts » Tue Mar 05, 2002 8:57 am
more amenable to packing a lot of stuff. It isn't as tall in the
middle where the M1 boot has the deeper well, but I haven't found that
to ever be a problem.
Will a case of wine fit in?
Mark Roberts
by Mark Roberts » Tue Mar 05, 2002 9:07 am
Mine too, aren't we the lucky ones.
Phil McArthur
by Phil McArthur » Tue Mar 05, 2002 11:13 am
Where are these lights in the bumper reflectors? Front or rear? Any
pictures?
Mark Roberts
by Mark Roberts » Tue Mar 05, 2002 4:15 pm
Front and rear, on the sides, red lenses at rear, orange at front.
Front ones are connected to indicator circuit. Some of you with
older imports may have lights without realising it - the cabling is
VERY exposed and subject to failure, as are the bulbs which aren't
noticed in WOF inspections. What I'm trying to say is you may have
them but they're busted.
Have sent photos to Phil.
p.mca@xtra.co.nz>
To: "MX5List" <
mx5list@mx5club.org.nz>
Subject: Re: Quiet times
Date sent: Tue, 5 Mar 2002 11:13:12 +1300
Send reply to: MX5List<
Scott Elder
by Scott Elder » Tue Mar 05, 2002 6:12 pm
In a box that sits on the parcel shelf. I've got a newer 1 in the making
which will be rounded to accomodate the top folded down a bit better. I have
to leave it for a while tho, 'cause I'm going to get a style bar and it will
have to take that into consideration.
my2cta
by my2cta » Tue Mar 05, 2002 9:24 pm
A very good question, so I just did the required experiment. If the cases
are lying on their sides you can fit 2 cases in the boot of an M2 easily.
It is wide enough for 3, but the boot is not quite as deep on the right
hand side as on the left (due to the battery placement) and a case doesn't
quite fit on the right as a result. A case of wine will not fit standing
up. Still, you are supposed to store wine on its side aren't you?
Tim Dutton
MY2CTA
Tim
MY2CTA
Return to “2002”
