Rust
ianbell
Rust
Post by ianbell » Tue Oct 18, 2005 7:33 am
Hammerite make a nice range of rust killer and rust preventative paints in a
range of colours as well as a primer. They seem to be very effective.
Ian Bell
Mikael Bjornstjerna
Rust
Post by Mikael Bjornstjerna » Tue Oct 18, 2005 10:37 am
Ian,
I checked out the Hammerite product brochure and it looks great. I'll
try it soonest.
Many thanks
Mike
Le 17 oct. 05, ` 20:33, Ian and Adele Bell a icrit :
From tonebeats@yahoo.co.nz Fri Apr 27 17:27:49 2007
DomainKey-Signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.co.nz;
b=Y0z8xDuffh/plqowF15lrWzPBI/VLgj2NiY+oeqG40X7B8a1Xf2p0LSUIBYxeFZWbQiRB47KeeeomSfaIanr0Yh2JLDRzdcIOG/N72AOZP8hCmpt4akaEgb5waxzKDIkjIXSxgAmjqiTWqZBZrE1/sEgqzftE+2FiDJhmA+TQ6U=
Date: Tue, 18 Oct 2005 10:43:09 +1300 (NZDT)
Subject: Re: Overheating saga continues
In-Reply-To: <f34ba891e2e06ef30de214f47931c150@online.fr>
MIME-Version: 1.0
Precedence: list
Message-ID: <C65Gk.A.KAE.ExYMGB@L733>
Unfortunatly they havnt made a paint that you can
spray on rust to remove it,i suggest you take your car
to a panel beater who should be able to cut the rust
out apply some sort of rust prevention,then put metal
back in the doors and prime an paint back to good as
new,good luck it pays to shop around and get the panel
beater to exsplain what he intends to do,you dont want
him to cut out rust and just bog it it wont last that way.Tony 91na
--- Mikael Bjornstjerna <bjornstjerna@online.fr>
wrote:
Mikael Bjornstjerna
Rust
Ian,
try it soonest.
Many thanks
Mike
MIME-Version: 1.0
Precedence: list
wrote:
Rex Johnston
Rust
Post by Rex Johnston » Tue Oct 18, 2005 2:15 pm
Mike,
Depending on where the rust is, you'll want to remove (i.e. scrape off,
sand etc etc) all the loose rust.
Then brush on some jenolite (phosphoric acid, turns the rust into an
iron phosphate skin). If the area
isn't easily visible, get some gripset (or similar bitumen emulsion) and
just paint it on. If it is visible,
you'll need to prime, undercoat and topcoat it.
Cheers, Rex
Mikael Bjornstjerna wrote:
Rex Johnston
Rust
Mike,
Cheers, Rex
Lyndon
Rust
Post by Lyndon » Tue Oct 18, 2005 4:56 pm
Has anyone suggested the POR-15 range of rust kill and prevent products?
Lyndon.
Lyndon
Rust
Lyndon.
Rust
Post by poison » Tue Oct 18, 2005 6:41 pm
IMHO the POR range is the best commercial grade product available, the saviour
of many hot rodders. Hammerite is more of the consumer grade.
"PO1SON"
Rust
"PO1SON"
Okibi
Rust
Post by Okibi » Tue Oct 18, 2005 8:01 pm
Another POR-15 fan here!
- Dave.
From jifjif@gmail.com Fri Apr 27 17:27:41 2007
h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references;
b=CPhqBuX7FXy2l0jHCxP6k8CENraQdlfuHFxfpx19lwpYh1m/3OXpaIFDqwaBP/GkDE+x55i6QcnsuCdn3zFcJBjUj3fDpkk0fSYqsOdNEgs/1RE6200I4A3/PHJ+uJaUJONSQMhzrj1pxzs2TvkRw8X45BMT2blzLAuWsRFg5/U=
Date: Tue, 18 Oct 2005 20:12:26 +1300
Subject: Re: wont idle
In-Reply-To: <001601c5d362$8dcb64e0$95cf36d2@maggie>
MIME-Version: 1.0
References: <000801c5d353$c93a13a0$95cf36d2@maggie>
<363634910510171351o5b37d203gb561f16ce32ae9dc@mail.gmail.com>
Precedence: list
Message-ID: <SH4dvC.A.XAE.ExYMGB@L733>
try a can of throttle body cleaner (not carb cleaner - more corrosive
apparently).
... and fuel injector cleaner while you're at it ;-)
let us know the results !
BTW - the fuel pimp doesn't run without the AFM signal - so I've discovered...
On 10/18/05, tim.maggie <tim.maggie@xtra.co.nz> wrote:
Okibi
Rust
- Dave.
MIME-Version: 1.0
Precedence: list
apparently).
Mikael Bjornstjerna
Rust
Post by Mikael Bjornstjerna » Tue Oct 18, 2005 8:54 pm
Hi Rex, Lyndon, Gazza & Tony,
Many thanks for good advice and to Rex + Lyndon: I cannot find IMHO on
the internet, also I need to find it in Europe.
Mike
Le 18 oct. 05, ` 03:15, Rex Johnston a icrit :
Mikael Bjornstjerna
Rust
Mike
Lyndon
Rust
Post by Lyndon » Tue Oct 18, 2005 9:26 pm
Search for POR or POR-15.
Lyndon.
Lyndon
Rust
Lyndon.
Rust
Post by poison » Tue Oct 18, 2005 9:33 pm
IMHO is computer talk for "In My Humble Opinion" just look for the POR.
Rust
Okibi
Rust
Post by Okibi » Tue Oct 18, 2005 9:33 pm
OR click here:
http://www.google.co.nz/search?hl=en
<http://www.google.co.nz/search?hl=en&q= ... earch&meta
=cr%3DcountryNZ> &q=%22POR-15%22&btnG=Google+Search&meta=cr%3DcountryNZ
- Dave
Okibi
Rust
OR click here:
- Dave
Okibi
Rust
Post by Okibi » Tue Oct 18, 2005 9:34 pm
Okibi
Rust
Mikael Bjornstjerna
Rust
Post by Mikael Bjornstjerna » Tue Oct 18, 2005 9:54 pm
Hi Gazza,
That became clear to me (!) but now I have found it under POR-15.
Thanks.
Mike
Le 18 oct. 05, ` 10:33, Gazza a icrit :
Mikael Bjornstjerna
Rust
Hi Gazza,
Thanks.
Mike
Mike Jolley
Rust
Post by Mike Jolley » Tue Oct 18, 2005 10:14 pm
Is POR Pink Or Red as in mx5 colour?No lets just stick to bagging BRG ho,ho.
MIKE
WEZTY
Mike Jolley
Rust
MIKE
WEZTY
Return to “2005”
