Stereo problem
Mikkels
Stereo problem
Post by Mikkels » Wed Dec 21, 2005 9:36 pm
Hi Guys
I have an issue with my stero in my 5. About two months ago
the headrest speakers original started making a high pitched
sound that rose and fell with engine RPM. Dead annoying so
I figured I needed new speakers. I replaced with the
warehouse speakers. All good for six weeks then suddenly I
have the sound back again.
What gives?
Don
MadMaz
Stereo problem
Post by MadMaz » Wed Dec 21, 2005 10:02 pm
Hi Don
It's likely not be an issue with the speakers themselves.
A high pitched sound that rises and falls in car speakers is related to
alternator load. When under heavy load (such as the lights on, cooling fan
right
up and/or AC on) it's common to hear a whine through speakers matched to
engine speed. Have you ever seen & heard rally car sequences on TV where
whine is heard in the intercom system varying with engine speed? Their high
output 150 + amp alternator units emit a strong field that's picked up by the
coils in the headsets.
First thing I'd do is to check the condition of your battery - if it's crook
the alternator will be made to work hard all the time because of the
increased resistance - if no joy check the regulator out on the alternator -
an auto electrician has all the gear to do this job.
Mark
Grant
Stereo problem
Post by Grant » Wed Dec 21, 2005 10:30 pm
Another common reason for alternator whine in any radio is poor earthing.
This can be caused by loose earth nuts, clamps, bolts etc. and maybe at the
antenna to body connection. As the alternators wear with age, the output is
more likely to generate whine as well. A faulty diode in the alternator is a
very common source of noise. This is a job for an auto electrician to repair.
The speakers will not be the cause but they needed to be replaced anyway.
Is the noise there at all times or does it vary with the volume setting. Is
the noise on the radio only (AM or FM) or is it there when using the CD or
tape player (or whatever it has). If the noise is there on the radio only,
does it go away when removing the antenna? If it's on the radio only, and
then only with the antenna connected you might have a faulty alternator
suppressor capacitor. Try a replacement.
Stereo problem
Post by poison » Wed Dec 21, 2005 10:34 pm
The Warehouse, The Warehouse, Where everyone returns their bargain...
I'm going with the battery/alternator too...
"PO1SON"
MadMaz
Stereo problem
Post by MadMaz » Wed Dec 21, 2005 11:07 pm
Hey Gazza
Re The Warehouse I know exactly what you mean - bought a large Transonic TV
from there once and it blew up only 3 months later.
A wag I know said this: "The Warehouse - Halfway between the Ship
and the Tip".
Mark
Return to “2005”
