Turbo Water Cooling
Turbo Water Cooling
Post by poison » Fri Nov 17, 2006 9:22 am
I’m looking at plumbing in the water cooling into the turbo, any thoughts about where to buy all the appropriate fittings and hoses?
Miatamad
Turbo Water Cooling
Post by Miatamad » Fri Nov 17, 2006 9:46 am
Indeed …
Greenlane Speed Shop
149 Station Rd Penrose Auckland
0-9-525 6858
For the return line you can just use fuel line (its not under pressure) – available from any Repco – or hell you can even pick it up with your fluffy dice at SuperCheap.
Like my post? Give me Karma!
Boosted. Scary fast.
Re: Turbo Water Cooling
Post by Growler » Fri Nov 17, 2006 1:40 pm
Miatamad wrote:Indeed …
0-9-525 6858
Shop around. Greenlane are bloody expensive!
You could try Cardwells (Auckland) as well...or grab a copy of the free "Hot Rod" type newspaper (Petrolhead magazine...I think it is called) that you can get at most car related businesses. They have a ton of suppliers there.
Post by SLYDIT » Fri Nov 17, 2006 5:06 pm
Try aeroquip, pirtek, or hydralink first..they will be cheaper.. the hardest part to get is the nipple( :wink: ) that threads into the turbo to adapt the standard hydraulic or "AN" hose fittings.....on my turbo its a 12mmX1.5mm thread which is as rare as rocking horse compost!
but as said before it aint cheap..budget for around $200 get the bits to add water cooling.
