6 Speed transplant
6 Speed transplant
Post by Ian » Thu Jul 06, 2006 9:34 pm
Has anyone fitted an NB 6 speed into an NA, or know of any web articles on this subject....??
Would also be keen to make contact with anyone who is using an NA in competition who may have considered this mod....
Post by poison » Thu Jul 06, 2006 10:24 pm
Hi Ian
If you don't mind my two cents worth. I've just bought an NB 6 speed and I think they box sucks, the 6th speed is the same as a normal 5 speed everything is just closer ratio.
The down side is instinct no longer works as to what gear you are in. 6th and 4th are just confusing when you put your hand down on the gear shift.
Plus as 6th is effectively in place of reverse they have had to make the sideways movement smaller to fit in the 3 forward gears (1st-2nd,3rd-4th, 5th-6th) but with reverse still back and left. So it's incredably easy to to screw up when changing down from 6th into 4th (5th really is a waste of time) as even the slightest hint of a push left and you are into second.... not good at 80+Km/hr.
Sure I will get used to it and then get confused driving a 5 speed. But I really think they have no tollerance for error and would be a pain on the track. I would be pretty happy to go back to a 5 speed gear box.
Post by Ian » Thu Jul 06, 2006 11:56 pm
Gazza...really appreciate your comments.
Leaving aside the 6th gear for a moment...I would anticipate only using 1st through 5th on Ruapuna with a 6sp box (given the final drive etc I have), or 4 speeds in my present box. I was figuring that is this case, having 5 gears to use would be an advantage...
Any other comments?
Bluesgeek
Post by Bluesgeek » Fri Jul 07, 2006 6:43 pm
I haven't found any advantage having 6 gears in our NC over the standard NA 5 speed gearbox.... yet... Its unfortunate having the reverse where it is, it's take a couple of weeks to really get used to it :(
