The missing "Check Engine" light
GEEMCB
Post by GEEMCB » Sun Jul 02, 2006 9:54 pm
OK - here's the silly question for the evening ....
I'm not convinced my O2 sensor is working. However if it has failed, apparently I should be getting a "code 15" on the "check engine" light. Sources - Haynes manual & the Garrett Performance Handbook. Both indicate that this is the case for pre 1995 cars (which mine is) - the 1995-onwards OBDII system means a fancy diagnostic thingie is required.
Now that's all well & good - but my instrument panel doesn't seem to have a "Check Engine" light. :oops: Also, when I check my (translated) owners manual there is mention of every sort of light except a "check engine" light. When the ignition is turned on I get charge, brake & (exhaust) heat lights coming up but nothing else.
So am I missing the blindingly obvious, misreading the information or is something else going on ? Is there another method for engine diagnostics (specifically O2 sensors)?
FTIW I took a look at David Moughtin's 1991/2 car today & it too is missing the elusive "check engine" light....... :?
Regards,
Greg
1990 V Special
Grant
Post by Grant » Sun Jul 02, 2006 10:22 pm
NZ new and Japanese imports don't have the check engine light. I think it is
a requirement for all cars in the USA now, and has been for some years. I
assume your manual is based on USA model cars.
[Posted via External Email]
Ben.Nakagawa
Post by Ben.Nakagawa » Mon Jul 03, 2006 10:28 am
Ben
GEEMCB
Post by GEEMCB » Mon Jul 03, 2006 9:00 pm
OK - so now I feel really silly !
Thanks, Grant & Ben - much appreciated. I just hate it when the information is right under my nose (happens quite frequently according to Glenys - but that's another story !) :oops:
As a matter of interest I dropped in at North Harbour Mazda today & asked what was involved in checking the diagnotics. I was quoted about an hour's worth of time or $90. :shock: Think I'll go & buy me a LED, resistor & paperclip ! :wink:
Regards,
Greg
1990 V Special
Post by zorruno » Mon Jul 03, 2006 9:53 pm
GEEMCB said on 07/03/2006 09:00 PM:
This may help:
http://www.mx5club.org.nz/maintenance/e ... agnostics/
Ben.Nakagawa
Post by Ben.Nakagawa » Mon Jul 03, 2006 10:20 pm
GEEMCB wrote: Thanks, Grant & Ben - much appreciated. I just hate it when the information is right under my nose (happens quite frequently according to Glenys - but that's another story !)
No worries, it happens to me as well.
Good luck to find what the code says.
Ben
