I'm having to replace my 15" BBS rims and am looking for advice on readily available alloy rims that will fit a NA. I have looked on TradeMe and most are 17" and above or fit FWD cars.
New Mk2 Mazda rims seem expensive at about $1100. Checked the local rim suppliers in Wgtn and Advanti is the most readily available rim at $700-800 per set. Would welcome any comments on quality, etc. Hart Racing and Volk are frequently mentioned as desirable rims but don't seem to be readily available. There are some Tiawan/Chinese rims available in the $650 range but aren't sure whether price is an indicator of quality.
Secondly would appreciate advice on offset. Have been advised by one supplier that one can fit a wheel in the 35-45mm offset range without any problems. Gives better handling and no problems with alignment.
Have seen some wheels with a 35mm offset that I like but uncertain other advice is that one should stay close to the 45mm offset.
Appreciate advice and direction I should look
15" wheels
Mark is absolutely right....
On an NA aim for 45mm (factory for all models I think), otherwise 40mm or 38mm at the max.
This is both a wheel bearing AND a handling issue. Equally important is the WEIGHT of the replacement wheel (Mazda went to great length to make light wheels, so put heavy rims on at your peril...) If appearance is your primary consideration, then none of the above needs to be taken into account...which is why you see a good number of overwheeled/tyred MX5s on the roads, with wildly inaccurate speedos I would imagine.
My NA facelift 1.8 runs Enkei (Made for 2002 Mazda NB) 40mm offset 15 x 6 on 195/50 x 15 in place of the original 14 x6 fitted with 185/60. I think all factory NBs run 40mm offset from memory...
There is plenty of web site info on wheels
