Awakening fruits is one of the most exciting progressions in Blox Fruits, giving players access to stronger abilities and more versatile combat options. Whether you are aiming to dominate in PvP or grind efficiently in raids, learning how to unlock awakened moves is a must. Below, I’ll break down the process and share some tips based on in-game experience.
What Are Awakened Moves?
Awakened moves are upgraded versions of a fruit’s abilities. Compared to the base skills, they often deal more damage, have better range, and come with improved utility. Not every fruit can be awakened, but many of the popular raid fruits such as Flame, Ice, Dark, and Light have powerful awakened forms.
Step 1: Unlock Raids
The first requirement for awakening is to participate in raids. To do this, you’ll need to be at least level 1100 and have access to the Second Sea. Raids can be started by purchasing a special chip from the Mysterious Scientist in the Second Sea. These chips usually cost fragments, which you can earn by defeating bosses, doing sea events, or participating in raids themselves.
Step 2: Gather Fragments
Fragments are the key currency for awakening. Each awakened move costs fragments to unlock, so you’ll want to save up plenty. A single raid can reward thousands of fragments depending on your performance, but higher-tier moves can cost quite a lot. Farming bosses and sea beasts is another solid way to gather them over time.
Step 3: Complete the Awakening Trials
During a raid, you and your team must defeat waves of enemies and a powerful boss within the time limit. If successful, you’ll be teleported to the Awakening Room. Here, you can choose to awaken one move at a time using fragments. For example, you might awaken your fruit’s main attack first, then work your way through the rest of the skill set.
Step 4: Plan Your Awakening Path
Awakening doesn’t have to be rushed. Some fruits benefit greatly from full awakening, while others only need one or two specific moves to be viable. If you’re grinding fragments, it’s a good idea to prioritize the abilities that make farming or PvP easier. For example, Ice and Dark awakenings are often favored early because of their crowd control and damage boosts.
Extra Tips for Success
Raids are easier with a coordinated crew. Teaming up not only speeds up clears but also reduces the chance of failing.
Stock up on useful gear and consider when to buy Blox Fruits items Roblox if you want to maximize your effectiveness in raids.
Players who like efficiency sometimes choose to buy blox fruits items such as weapons or accessories to help them through challenging content.
Awakened moves in Blox Fruits are a game-changer, but they require patience, teamwork, and plenty of fragments. Once unlocked, they provide a significant advantage in both grinding and PvP. Focus on the fruits and abilities that fit your playstyle, and you’ll find that awakening opens the door to a much more powerful endgame experience.
How to Get Awakened Moves in Blox Fruits
