Rust
Rust
Ian,
I checked out the Hammerite product brochure and it looks great. I'll
try it soonest.
Many thanks
Mike
Le 17 oct. 05, ` 20:33, Ian and Adele Bell a icrit :
From tonebeats@yahoo.co.nz Fri Apr 27 17:27:49 2007
DomainKey-Signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.co.nz;
b=Y0z8xDuffh/plqowF15lrWzPBI/VLgj2NiY+oeqG40X7B8a1Xf2p0LSUIBYxeFZWbQiRB47KeeeomSfaIanr0Yh2JLDRzdcIOG/N72AOZP8hCmpt4akaEgb5waxzKDIkjIXSxgAmjqiTWqZBZrE1/sEgqzftE+2FiDJhmA+TQ6U=
Date: Tue, 18 Oct 2005 10:43:09 +1300 (NZDT)
Subject: Re: Overheating saga continues
In-Reply-To: <f34ba891e2e06ef30de214f47931c150@online.fr>
Message-ID: <C65Gk.A.KAE.ExYMGB@L733>
Unfortunatly they havnt made a paint that you can
spray on rust to remove it,i suggest you take your car
to a panel beater who should be able to cut the rust
out apply some sort of rust prevention,then put metal
back in the doors and prime an paint back to good as
new,good luck it pays to shop around and get the panel
beater to exsplain what he intends to do,you dont want
him to cut out rust and just bog it it wont last that way.Tony 91na
--- Mikael Bjornstjerna <bjornstjerna@online.fr>
try it soonest.
Many thanks
Mike
wrote:
Rust
Ian,
try it soonest.
Many thanks
Mike
try it soonest.
Many thanks
Mike
wrote:
Rust
Mike,
Depending on where the rust is, you'll want to remove (i.e. scrape off,
sand etc etc) all the loose rust.
Then brush on some jenolite (phosphoric acid, turns the rust into an
iron phosphate skin). If the area
isn't easily visible, get some gripset (or similar bitumen emulsion) and
just paint it on. If it is visible,
you'll need to prime, undercoat and topcoat it.
Cheers, Rex
Cheers, Rex
Rust
Mike,
Cheers, Rex
Cheers, Rex
Rust
Another POR-15 fan here!
- Dave.
From jifjif@gmail.com Fri Apr 27 17:27:41 2007
h=received:message-id
b=CPhqBuX7FXy2l0jHCxP6k8CENraQdlfuHFxfpx19lwpYh1m/3OXpaIFDqwaBP/GkDE+x55i6QcnsuCdn3zFcJBjUj3fDpkk0fSYqsOdNEgs/1RE6200I4A3/PHJ+uJaUJONSQMhzrj1pxzs2TvkRw8X45BMT2blzLAuWsRFg5/U=
Date: Tue, 18 Oct 2005 20:12:26 +1300
Subject: Re: wont idle
In-Reply-To: <001601c5d362$8dcb64e0$95cf36d2@maggie>
References: <000801c5d353$c93a13a0$95cf36d2@maggie>
<363634910510171351o5b37d203gb561f16ce32ae9dc@mail.gmail.com>
Message-ID: <SH4dvC.A.XAE.ExYMGB@L733>
try a can of throttle body cleaner (not carb cleaner - more corrosive
apparently).
... and fuel injector cleaner while you're at it
let us know the results !
BTW - the fuel pimp doesn't run without the AFM signal - so I've discovered...
On 10/18/05, tim.maggie <tim.maggie@xtra.co.nz> wrote:
- Dave.
apparently).
Rust
- Dave.
apparently).
- Dave.
apparently).
Rust
OR click here:
http://www.google.co.nz/search?hl=en
<http://www.google.co.nz/search?hl=en&q= ... earch&meta
=cr%3DcountryNZ> &q=%22POR-15%22&btnG=Google+Search&meta=cr%3DcountryNZ
- Dave
- Dave
Rust
OR click here:
- Dave
- Dave
Rust
Rust
