Overheating
joanie
Overheating
Post by joanie » Wed Oct 19, 2005 4:52 pm
removing a theromstat is fairly easy, it requires new coolant fluid
afterwards tho'. ...
So do I gather the MX5 thermostat is not a sealed unit? Jolly good ...I am
sure we will have to deal with ours sooner or later :-)
JH
Overheating
Post by Euen » Wed Oct 19, 2005 8:39 pm
For those interested, it is possible to get a thermostat that opens at a
cooler temperature. The normal one opens at about 88 degrees C but this one
opens at about 76 deg. For the BP 1800cc, the Tridon part number is
TT240-170. Not sure if the 1600 is the same.
There has been some debate on Miata.Net about how much they help as the ECU
uses water temperature as one of its measurements but in theory they should
help a performance engine to stay a bit cooler.
Liz
Overheating
Post by Liz » Wed Oct 19, 2005 8:56 pm
Hi Gang.
Does anyone have any advice for fitting after market speakers in the mx5
head rests, The new system I installed promptly blew the poor origional
little speakers to bits.
Craig
Return to “2005”
