OH FFS! car wont start!
Post by Angreal » Mon Nov 19, 2012 10:29 pm
SLYDIT wrote:if anyone has any parts such as CAS/ignitor/coilpack/ECU that they dont mind lending out please let me know.
http://www.trademe.co.nz/motors/car-par ... 436671.htm
Post by siren676 » Mon Nov 19, 2012 11:10 pm
SLYDIT wrote:my fp is loud...always has been. turn your radio off and listen in your garage. you probably have no hope outside on the road. you wont hear it with the engine running.
I tried listening for it the other night but could only hear the relay clicking on and off, fuel line was probably still pressurised so the pump didnt need to turn on.
Will try in the morning before heading to work
Post by WideOpenThrottle » Tue Nov 20, 2012 7:56 am
My fuel pump comes on just with ignition..but thats because of the megasquirt now i think.
Post by WideOpenThrottle » Tue Nov 20, 2012 8:22 am
More info..
Post by SLYDIT » Tue Nov 20, 2012 6:32 pm
SOLVED!
Seeing as the car wasnt going anywhere, i decided to do a bit of other work on it.
I pulled the ECU to give the ecu bracket some paint so pulled the covers off and discovered corrosion on the 1A/1B/1C pins on the ecu plug where they join the board so cleaned it up and resoldered the connections and hey presto. car is back to life. Fuel pump still doesnt run in acc like it did, but everything seems to be ok...oh well off to whangamata this weekend!
*\0/*
Users browsing this forum: Majestic-12 [Bot] and 15 guests
