What else should I be doing while all these parts are off...
Post by Mad Kiwi » Wed Mar 14, 2012 8:07 am
Hi Guys
I am in the middle of installing a 949 Racing "M-Tuned" coolant reroute.
Currently have CAS out, rear water housing off, Valve Cover off (for painting) etc.
I intend on replacing the CAS seal and heater hoses, anyone else think of other things to do while the rear access is improved?
Mark
Post by Kieran » Wed Mar 14, 2012 10:18 am
remove the bolt under the coil pack its a bitch to get with the motor in and its useless
Post by Mad Kiwi » Wed Mar 14, 2012 10:53 am
Thanks Kieran, that was one I had been considering.
Post by Kieran » Wed Mar 14, 2012 11:18 am
yeah i spent too long trying to get it out when i took the valve cover off
Post by sprsta » Wed Mar 14, 2012 12:39 pm
I did the BEGI reroute
for the hose i used the same one as in this article
http://revlimiter.net/blog/2011/05/coolant-re-route-1/
http://revlimiter.net/blog/2011/06/coolant-re-route-2/
i searched high and low and eventually born_desturbed found me one at Bunce motors in wairau
it worked really well
good luck
Users browsing this forum: Bing [Bot] and 44 guests
