by brownie » Mon Mar 12, 2012 10:25 pm
Show and tell what you got,Homemade,Custom Built or off the shelf.
I'll get the ball rolling.
4 systems to choose from,Finally put the Maxum/Corn*s system on.
Wicked sound ,noisy without being loud and booming,wicked cackle on over run.
2.5" all the thru,with Cat built onto it ,Found out these are worth a bomb,Hand built out of Japan.
Other choice's i had;
Standard with wanky tip.
St Mays shot gun system
Racing Beat by RS*R
The RB system was going to be my second choice if i didn't like the corn*s system sound,But i do
brownie on Tue Mar 13, 2012 5:16 pm, edited 1 time in total.
by Growler » Mon Mar 12, 2012 11:02 pm
Mine is custom. I removed the cat and replaced it with a straight through expansion box/muffler. I increased the pipe diameter to 2" (Did think of 2 1/4" but was concerned about losing too much back pressure). The rear muffler is a V8 Commodore. I wanted to muffle the sound but not hinder the flow.
I'm happy with the sound and increase in performance (in the higher rev range).
I have a set of 4 - 2 - 1 headers to put on it at some stage.
Its slow work in progress as I never have much time to work on cars these days.
by Born_disturbed » Tue Mar 13, 2012 10:25 am
I am running (assuming nothing had been changed before i got it) full factory piping with a straight pipe for the cat and a mazdaspeed tip
Can be a bit loud but I am still happy with it, do want to get a full proper set up eventually
by Angreal » Tue Mar 13, 2012 11:41 am
Maximworks 4-2-1 header with hpc, RB mid-pipe in transit and a Mazdaspeed tip thing. Sounded a lot nicer prior to having my cat chopped out hence the mid-pipe
by Kieran » Tue Mar 13, 2012 1:11 pm
Ive got a fujitsubo fgk rear axle back with the stock midpipe its a great hand made japanese muffler but...
I want an rs*r!!
by brownie » Tue Mar 13, 2012 5:10 pm
This is a Racing Beat ,Made by RS*R.
And yes i could be persuaded to part with it.
But it is to suit a NA 1600
by brownie » Wed Mar 14, 2012 5:05 pm
Nope RS*R made Racing Beat under license in Japan,I,ve had it all checked out.
dumbfounded me too.
- RB7.jpg (36.39 KiB) Viewed 17491 times
by Kieran » Wed Mar 14, 2012 5:48 pm
Well thats wierd never heard of that
The rs*r i want is the exmag gt2 i think its called
by sprsta » Wed Mar 14, 2012 7:03 pm
i had a 3" system with mandrel bends etc. a flow master at the back and a reso from chase
made it all on the floor of my garage
i dont think ill do another one without a hoist
Blues Boy
by Blues Boy » Wed Mar 14, 2012 10:22 pm
I've got a RS*R 4-2-1 header and a Autoexe cat-back... It's perfect for me... pretty tame while cruising, but has a nice sound when you give it some throttle...
Dave
by Born_disturbed » Wed Mar 14, 2012 10:47 pm
That looks real nice and clean, i like that
thebears
by thebears » Sat Mar 17, 2012 11:38 am
Blues Boy wrote:I've got a RS*R 4-2-1 header and a Autoexe cat-back... It's perfect for me... pretty tame while cruising, but has a nice sound when you give it some throttle...
I like
m4vr1k
by m4vr1k » Sun Mar 18, 2012 1:54 pm
I have a very special exhaust on the Mazdarati.
It is completely factory, with the optional heat shields that trap stones and rattle really loudly on acceleration. And deceleration. And idle. Also it hits my rear brace, making a fun "clunk" every time you get off the gas.....
However, once I get into the turbo build, I will be replacing it with a 2.5 inch mandrel bent system from my local exhaust stop. 3 inch just seems a little excessive, and I want to keep the volume too.
Roses are red
Violets are red
Trees are red
Oh fuck, my garden's on fire
