NA Minilites not fitting on hubs
Hi
My NA came with 15 inch rims. I tried to put the standard minilites back onto night. No joy. If this makes any sense...the center of hub is larger than the hole in the minilite as such the wheel will not fit flush on hub.
Is it possible someone has changed the rotors or are they same NA/NB
Many thanks
Paul
Many thanks
Paul
Standard Minilites? MX-5s never came standard with Minilite wheels. I think that may be your problem, you've got non-standard wheels with too small a center bore.
Unless you mean the factory "daisy" wheels, in which case you've obviously got non-standard hubs, which sounds bizarre. Measure your hub diameter, it should be ~54.1mm I believe is standard.
Mr. Shine wrote:Standard Minilites? MX-5s never came standard with Minilite wheels. I think that may be your problem, you've got non-standard wheels with too small a center bore.
Yes they are the factory daisy wheels. Checked the hub 66mm. Go figure! Are the NB rotors any different than the NA?
Users browsing this forum: No registered users and 70 guests
