Oil Filters, suggestions, brands to avoid etc...
Hi Guys
I "think" I have read on some forums that some oil filters can direct bypass under certain conditions.
However this may be for other vehicles I was studying over the years....
Anyone brand better than the rest, all the same etc...sugestions?
Mark.
Mark.
Ummmm,got my car about 5 years ago and done just the one oil change when i got it
,Mind you have only done a couple of thousand kays since owning it,Oil is still a good colour and hasn't burnt any.
I don't get to drive it often,But when i do i give shit....Safely as conditions allow.
But should do a oil and filter about once a year or 10,000km depending on how you use it,Higher grade fuel does help the engine oil stay cleaner for longer too.
I change my oil every 5000km, but usually change filter every second oil change, so every 10000km for me.Mad Kiwi wrote:How frequently do you guys change the filter, or suggest on a track day / fang car....
I use synthetic oils, 10W-40 is a good weight to start with. You could easily go up to a 15W-40 or down to a 5W-40. I prefer 10W-40 or 5W-40 myself, as I've found 15W-40 gives me a bit of noise - presumably from the hydraulic lash adjusters.Also, Seeing as oil weight comes up, what is the consensus on weight and you may as well throw in favoured brands, sources, price etc
If you're one for oil flushes, I usually use a litre of thick, cheap oil and two or three litres of ATF. Let it idle for an hour or so, or take it on a short and GENTLE drive. Don't give the engine shit at this point because you've got very thin oil in your engine with this mixture. After you've let it circulate well through the engine, drain it all out very thoroughly, then replace with your good 10W-40 synthetic and a new filter.
